Home » Modeling » EMF » [xcore] derived feature does not allow class types
[xcore] derived feature does not allow class types [message #1736516] Thu, 30 June 2016 02:01 Go to next message
I have an xcore file with the following classes:
class Information {
String sName
String birthday
String age
class Directory {
String name
String address
derived Information xInfo get {
  //call the get method here that will return a type Information
But I am getting this error:
The generic attribute type must not refer to a class
How can I use the derived feature with a class?
[Updated on: Thu, 30 June 2016 04:54] by Moderator
Re: [xcore] value is not stored when set via xtend [message #1736569 is a reply to message #1736516] Thu, 30 June 2016 07:38 Go to previous messageGo to next message
Chris,
Comments below.
> class Information {
> String sName
> String birthday
> String age
> class Directory {
> String name
> String address
> contains Information xInfo
> The xInfo variable is populated during validation.
Modifying the model during validation doesn't sound appropriate. That's
probably operating on a model that's loaded and then discarded.
> So, I have an xtend method that sets this.
> public static val aDirs = new ArrayList<Directory>
> public static val aInfo = new ArrayList<Information>
> def public setInfo()
> for (m: aDirs)
> val x = aInfo.findFirst[m.name.equals(SName)]
> if (x != null)
> m.xInfo = x //print also shows that this is correctly set.
> def public printInfo()
> for (m: aDirs)
> if (m.xInfo == null) // check if null, this returns true.
> // do nothing
> With the two methods above, I called setInfo() and then printInfo(),
> but in printInfo(), xInfo variable is null again.
> aDirs and aInfos are populated during transform.
> What am I doing wrong?
Best you set a breakpoint and debug it. I can't guess what might be
missing.
Re: [xcore] value is not stored when set via xtend [message #1736645 is a reply to message #1736569] Thu, 30 June 2016 14:24 Go to previous messageGo to next message
Hi Ed,
I tried to change the contents of the xcore class to a derived feature but somehow, it is throwing me an error.
"The generic attribute type must not refer to a class".
Is it possible to use the derived feature like this:
return MyVariables::aInfo.findFirst[name.equals(SName)]
Re: [xcore] value is not stored when set via xtend [message #1736651 is a reply to message #1736645] Thu, 30 June 2016 17:48 Go to previous message
Chris,
Yes, but Information is a class so the feature needs to be a reference
(using the refers keyword).
On 30.06.2016 14:24, chris yo wrote:
> Hi Ed,
Previous Topic:Managing dependencies between EMF resources.
Next Topic:[xcore] How to set a class type variable
Current Time: Sun Jul 20 19:52:21 EDT 2025
Powered by FUDForum. Page generated in 0.04507 seconds
