How to get eclipse base plugins jar [message #1736029] |
Fri, 24 June 2016 09:26  |
I am trying to build my own plugins using maven. which are using the below dependency
org.eclipse.core.runtime;bundle-version="3.11.0"
I am able to compiled successfully these set of plugin in my local eclipse 4.5.
However when I try to build the same set of plugin from maven with the help of nexus url which actually points to eclipse release url "http://download.eclipse.org/releases/mars/" repository created as below in my pom.xml
<repository>
<id>eclipse-mars</id>
<url>https://dsnexus-xxx:8083/nexus/content/repositories/eclipse-mars-release</url>
<layout>p2</layout>
</repository>
so this nexus url is unable to find the above bundle(org.eclipse.core.runtime 3.11.0) and giving below error.
" Missing requirement: com.modelling.emf.castormapping1_0 1.0.0.qualifier requires 'bundle org.eclipse.core.runtime 3.11.1' but it could not be found "
When I checked in nexus and found that org.eclipse.core.runtime 3.11.0 plugin is not there it means its not present at "http://download.eclipse.org/releases/mars/" also.
and the above bundle/jars resides under installed eclipse plugin folder and that was the reason it gets compiled in local eclipse.
Till now I was assuming that all the basic jars will be available in eclipse release repository but that is not the case.
So my question is, is there any eclipse repository url which will have all the basic plugins are resides. Please let me know if there is any update sites where all the eclipse base plugins are available.
[Updated on: Mon, 27 June 2016 00:47] by Moderator
Re: How to get eclipse base plugins jar [message #1737794 is a reply to message #1737748] |
Wed, 13 July 2016 01:18  |
Umesh,
I'm not sure you're using Tycho correctly. Perhaps better to ask via
https://eclipse.org/tycho/support.php
We use Tycho Maven for Oomph, and we don't use those repos the way you
do. Our parent POM refers to our releng plugin for the target:
http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/releng/org.eclipse.oomph.parent/pom.xml#n111
That project has a *.target file:
http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/releng/org.eclipse.oomph.releng
And the dependencies in that file are used by Tycho to resolve the
target platform.
But I'm no expert and Eike Stepper implemented this build
infrastructure. So I won't be able to answer anything in detail. Better
to Google, look at Oomph as a working example, and ask Tycho-specific
questions on their support channel.
On 12.07.2016 15:07, Umesh Thakare wrote:
> Hi
> I have tried the mars release url which you mention in your post but
> still i am facing the same issue.
> So now i have created one sample application to check whether given
> url is working or not
> I have created one hellow world plugin in eclipse 4.5(mars). In which
> i have added two below dependency on the manifest file(MANIFEST.MF).
> org.eclipse.core.runtime;bundle-version="3.11.1",
> org.eclipse.emf.ecore;bundle-version="2.11.1"
> And MANIFEST.MF file looks like below
> Manifest-Version: 1.0
> Bundle-ManifestVersion: 2
> Bundle-Name: Maven_building
> Bundle-SymbolicName: com.qvto.maven_building;singleton:=true
> Bundle-Version: 1.0.0.qualifier
> Bundle-Activator: com.qvto.maven_building.Activator
> Bundle-Vendor: NAME
> Require-Bundle: org.eclipse.ui;bundle-version="3.107.0",
> Bundle-RequiredExecutionEnvironment: JavaSE-1.6
> Bundle-ActivationPolicy: lazy
> please find the snipped code of pom.xml which i have used to build my
> plugin using maven.
> Please find the snipped code below:-
> <project xmlns="http://maven.apache.org/POM/4.0.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://maven.apache.org/POM/4.0.0
> http://maven.apache.org/xsd/maven-4.0.0.xsd">
> <modelVersion>4.0.0</modelVersion>
> <groupId>com.qvto.maven_building</groupId>
> <artifactId>com.qvto.maven_building</artifactId>
> <version>0.0.1-SNAPSHOT</version>
> <packaging>eclipse-plugin</packaging>
> <name>Engineering Tool Parent</name>
> <properties>
> <tycho-version>0.17.0</tycho-version>
> <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
> </properties>
> <repositories>
> <repository>
> <id>mars-eclipse</id>
> <layout>p2</layout>
> <url>http://download.eclipse.org/releases/mars/201602261000/</url>
> </repository>
> </repositories>
> <build>
> <plugins>
> <plugin>
> <groupId>org.eclipse.tycho</groupId>
> <artifactId>tycho-maven-plugin</artifactId>
> <version>${tycho-version}</version>
> <extensions>true</extensions>
> </plugin>
> <plugin>
> <artifactId>tycho-compiler-plugin</artifactId>
> <configuration>
> <source>1.6</source>
> <target>1.6</target>
> </configuration>
> </plugin>
> <plugin>
> <artifactId>target-platform-configuration</artifactId>
> <configuration>
> <resolver>p2</resolver>
> <environments>
> <environment>
> <os>win32</os>
> <ws>win32</ws>
> <arch>x86</arch>
> </environment>
> <environment>
> <os>linux</os>
> <ws>gtk</ws>
> <arch>x86</arch>
> </environment>
> </environments>
> <filters>
> <filter>
> <type>eclipse-plugin</type>
> <id>org.antlr.runtime</id>
> <restrictTo>
> <versionRange>[3.0.0,3.0.2)</versionRange>
> </restrictTo>
> </filter>
> <filter>
> <id>com.google.inject</id>
> <restrictTo>
> <versionRange>[2.0.0,2.0.1)</versionRange>
> </restrictTo>
> </filter>
> </filters>
> </configuration>
> </plugin>
> </plugins>
> </build>
> </project>
> So after adding dependency and creating pom when i try to build using
> maven, i face the below problem
> Missing requirement: com.qvto.maven_building 1.0.0.qualifier requires
> So still i am facing the same type of issue even i have change the
> repository which you share with us.
> Please help me on this problem
FUDForum. Page generated in 0.12978 seconds
