Home » Eclipse Projects » Eclipse Titan » Ignore any unsolicited message
Ignore any unsolicited message [message #1735748] Wed, 22 June 2016 08:01 Go to next message
I want to wait for a message from either port1 or port2 and if any message comes in any other port, it should be handled separately (in some altstep) and the function should wait for receiving the message from port1 or port2.
I have code similar to the following:
function receive_messages() {
    activate(default_altstep);  //handles all messages except from port1 or port2
    alt {
        port1.receive {}
        port2.receive {}
    deactivate(default_altstep);
But in this code, if message other then what is expected in the alt is received the alt exits and the control goes to the default_altstep and then the function terminates.
I can't understand the problem with this code or any other approach.
Please help.
Re: Ignore any unsolicited message [message #1735751 is a reply to message #1735748] Wed, 22 June 2016 08:37 Go to previous message
Hi Murli,
to achieve this, you need to restart the evaluation of alt by for example inserting it into a loop, as below:
var boolean  v_loop:=true;
while (v_loop)
    alt {
        []port1.receive {
		v_loop:=false
        []port2.receive {
		v_loop:=false
    }//endalt
}//endwhile
}//endfunction
while will be executed until you receive something on port 1 or 2; this will also break the loop by setting v_loop to false.
I hope this helps
Best regards
Elemer
Previous Topic:Using ASN Style Assignment in TTCN
Next Topic:Advanced TTCN-3 usage: working with record of structures when performance matters
Current Time: Sat Jul 19 23:41:35 EDT 2025
Powered by FUDForum. Page generated in 0.03970 seconds
