[CDO] Problems with concurrent transactions [message #1735733] |
Wed, 22 June 2016 06:39  |
I am seeing some problems running multiple CDOTransactions concurrently within the same session (using JVM connector and MEMStore backend. Running with Mars and CDO 4.4 SR2)
I have created an empty MemStore based repository.
I open a transaction, create a new resource and store a element in there.
ELEMENT_PATH = "/root.xmi"
final CDOTransaction t = session.openTransaction();
final CDOResource r = t.createResource(ELEMENT_PATH);
final MyCDOObject instance = ...;
r.getContents().add(instance);
// Record the timestamp
CDOCommitInfo commitInfo = t.commit();
timestamp = commitInfo.getTimeStamp();
t.close();
Then I get a new view and pull out the object instance
final CDOView baseView = session.openView(timestamp);
baseView.waitForUpdate(timestamp);
final CDOResource baseResource = baseView.getResource(ELEMENT_PATH);
final MyCDOObject baseInstance = (MyCDOObject ) baseResource.getContents().get(0);
I then create a number of runnables with the following code below and submit to a ExecutorService
for (int retryNumber = 0; retryNumber <commitRetryCount; ++ retryNumber) {
CDOTransaction transaction = session.openTransaction();
// Ensure the first commit has been processed (is this needed given shared session?)
transaction.waitForUpdate(timestamp);
// Grab the transaction version of the object.
MyCDOObject transactionInstance = transaction.getObject(baseInstance);
Assert.assertNotNull(transactionInstance);
try {
<ADD NEW ELEMENT TO ROOT OBJECT>
transaction.commit();
// No need to retry
break;
} catch (CommitException e) {
// CommitException - assume concurrent modification and retry
transaction.rollback();
// Report error if we hit our limit
if (retryNumber >= commitRetryCount - 1) {
e.printStackTrace();
Assert.fail(e.getMessage());
// Add delay to allow other commits to execute
try {
Thread.sleep(new Random().nextInt(100));
} catch (final Exception ee) {
ee.printStackTrace();
} catch (Exception e) {
// Some other kind of exception, abort immediately
Assert.fail();
} finally {
// Clean up
transaction.close();
This will sometimes pass, but I am also getting a range of exceptions. These are EOFException, ArrayIndexOutOfBounds and InvalidURIException (which seems strange as it does exist and I have even used the waitForUpdate call) - see below for example stack traces.
Can anyone advise?
Simon
EOFException stack trace
java.util.concurrent.ExecutionException: org.eclipse.emf.cdo.common.util.TransportException: java.io.EOFException
at java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.util.concurrent.FutureTask.get(FutureTask.java:192)
at org.example.CDOBasedTest.test(CDOBasedTest.java:259)
at org.example.CDOBasedTest.theTest(CDOBasedTest.java:156)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: org.eclipse.emf.cdo.common.util.TransportException: java.io.EOFException
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:565)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.unlockObjects2(CDOClientProtocol.java:370)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.unlockObjects(CDOViewImpl.java:602)
at org.eclipse.emf.internal.cdo.view.CDOViewImpl.unlockObjects(CDOViewImpl.java:562)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.handleRollback(CDOTransactionImpl.java:1702)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.rollback(CDOSingleTransactionStrategyImpl.java:110)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.rollback(CDOTransactionImpl.java:1357)
at org.example.CDOBasedTest.lambda$0(CDOBasedTest.java:217)
at org.example.CDOBasedTest$$Lambda$1/21422054.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.EOFException
at java.io.DataInputStream.readInt(DataInputStream.java:392)
at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readInt(ExtendedDataInput.java:107)
at org.eclipse.emf.cdo.internal.net4j.protocol.UnlockObjectsRequest.confirming(UnlockObjectsRequest.java:99)
at org.eclipse.emf.cdo.internal.net4j.protocol.UnlockObjectsRequest.confirming(UnlockObjectsRequest.java:1)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:97)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:369)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:466)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:557)
... 13 more
ArrayIndexOutOfBoundsException:
java.util.concurrent.ExecutionException: org.eclipse.net4j.signal.RemoteException: java.lang.ArrayIndexOutOfBoundsException: 126
Caused by: org.eclipse.net4j.signal.RemoteException: java.lang.ArrayIndexOutOfBoundsException: 126
at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:489)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:62)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 126
at org.eclipse.net4j.util.io.ExtendedIOUtil.readEnum(ExtendedIOUtil.java:363)
at org.eclipse.net4j.util.io.ExtendedDataInputStream.readEnum(ExtendedDataInputStream.java:49)
at org.eclipse.net4j.util.io.ExtendedDataInput$Delegating.readEnum(ExtendedDataInput.java:150)
at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOLockType(CDODataInputImpl.java:388)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.UnlockObjectsIndication.indicating(UnlockObjectsIndication.java:52)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.indicating(CDOServerIndication.java:86)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerWriteIndication.execute(CDOServerWriteIndication.java:39)
... 5 more
InvalidURIException
org.eclipse.emf.cdo.util.InvalidURIException: Invalid URI "cdo://423fc2be-9fb8-451a-9fe7-6c5ce8547402/root.xmi": org.eclipse.emf.cdo.common.util.CDOException: No top level ResourceNode with the name root.xmi
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource2(AbstractCDOView.java:1576)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.attachResource(AbstractCDOView.java:1541)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.attachResource(CDOTransactionImpl.java:1011)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.basicSetResourceSet(CDOResourceImpl.java:1671)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$ResourcesEList.inverseAdd(ResourceSetImpl.java:586)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:286)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:435)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getResource(AbstractCDOView.java:889)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.newResourceInstance(AbstractCDOView.java:1321)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:1281)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:1168)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getObject(CDOTransactionImpl.java:1233)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.convertIDToObject(AbstractCDOView.java:1516)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertIDToObject(CDOStoreImpl.java:689)
at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.getResource(CDOStoreImpl.java:139)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.createObject(AbstractCDOView.java:1296)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getObject(AbstractCDOView.java:1217)
at org.example.CDOBasedTest2.lambda$0(CDOBasedTest2.java:195)
at org.example.CDOBasedTest2$$Lambda$1/212011969.run(Unknown Source)
at org.example.ConcurrencyTestUtil$1.run(ConcurrencyTestUtil.java:44)
Caused by: org.eclipse.emf.cdo.common.util.CDOException: No top level ResourceNode with the name root.xmi
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getRootOrTopLevelResourceNodeID(AbstractCDOView.java:827)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.getRootOrTopLevelResourceNodeID(CDOTransactionImpl.java:1190)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getResourceNodeID(AbstractCDOView.java:766)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getResourceNodeIDChecked(AbstractCDOView.java:733)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.getResourceNodeID(AbstractCDOView.java:718)
at org.eclipse.emf.internal.cdo.view.AbstractCDOView.registerProxyResource2(AbstractCDOView.java:1559)
... 29 more
FUDForum. Page generated in 0.15210 seconds
