Home » Eclipse Projects » BPMN 2.0 Modeler » How to open bpmn files properly
How to open bpmn files properly [message #1735047] Tue, 14 June 2016 18:31 Go to next message
I'm trying to open bpmn files programmatically, but without success until now. First, I'm getting the URI (java.net.URI) from bpmn file, but method BPMN2Editor.openEditor(modelURI) has another implementation of URI as parameter (org.eclipse.emf.common.util.URI).
Facing this question, I did a conversion from java.net.URI to o.e.emf.common.util.URI.
java.net.URI javanetURI = project.getFolder("FolderName").getFile("FileName").getLocationURI();
org.eclipse.emf.common.util.URI modelURI;
modelURI = org.eclipse.emf.common.util.URI.createURI(javanetURI.toString());
BPMN2Editor.openEditor(modelURI);
But even this way, when I called openEditor method, I got the "Failed to create the part's controls" error.
http://i.imgur.com/arzG58O.png
I don't know whats going on. Hope someone have a tip for this.
Thank you,
Delacyr
[Updated on: Tue, 14 June 2016 18:35] by Moderator
Re: How to open bpmn files properly [message #1735051 is a reply to message #1735047] Tue, 14 June 2016 19:29 Go to previous messageGo to next message
Take a look at the BPMN2DiagramWizard.performFinish() and BPMN2DiagramCreator.
Re: How to open bpmn files properly [message #1735150 is a reply to message #1735051] Wed, 15 June 2016 17:40 Go to previous message
Thank you Bob, it helped me and now it works. The new code follows below.
IPath path_BPDFolder = project.getFolder("FolderName").getFullPath().append("FileName");
modelURI = org.eclipse.emf.common.util.URI.createPlatformResourceURI(path_BPDFolder.toString(), true);
[Updated on: Wed, 15 June 2016 17:41] by Moderator
Previous Topic:Help save the BPMN2 Modeler Project from extinction!
Next Topic:How to use a custom icons?
Current Time: Sun Jul 20 07:49:34 EDT 2025
Powered by FUDForum. Page generated in 0.03989 seconds
