Home » Eclipse Projects » Mosquitto » Publishing multiple messages continuously to the server(Publishing multiple messages continuously to the server)
Publishing multiple messages continuously to the server [message #1708996] Wed, 23 September 2015 04:15 Go to next message
I am using MQTT client for publishing multiple messages and files to the server .The publisher should run continuously taking the differnet files from the local directory and should publish to the server. My qn is ,
How to publish multiple messages/files with a single client.
Should I need to start the publisher in asynchronous mode.
if so what call_back function should be called inside the publisher main().
Kindly advice
icon4.gif  mosquitto brokker accepting any username and password [message #1734590 is a reply to message #1708996] Thu, 09 June 2016 11:19 Go to previous message
I have downloaded the source code of mosquitto from mosquitto.org/download/.
i have done
in mosquittox.x.x.x directory
make
modified the mosquitto.config file allow_anonymous false
in mosquittox.x.x.x/src directory
created the passwordfile using command
./mosquitto_passwd -c passwordfile username password
then running the mosquitto_sub and mosquitto_pub with any username and password its gets connected with the broker.
What to do so that it connects with the broker with correct username and password???
@jinto
Previous Topic:Mosquitto on linux server(GoDaddy,HostGator)
Next Topic:When reconnect, Broker using "Bridge(in) connection" doesn't send messages.
Current Time: Sat Jul 19 17:10:03 EDT 2025
Powered by FUDForum. Page generated in 0.16313 seconds
