Home » Language IDEs » C / C++ IDE (CDT) » how can I Automatic commented code
how can I Automatic commented code [message #1732871] Fri, 20 May 2016 22:27 Go to next message
In the Eclipse for Java,I can used ctrl+shift+j to Automatic commented code with the parameter.
Anybody knows how to solve this problem?thank you.
Re: how can I Automatic commented code [message #1732969 is a reply to message #1732871] Mon, 23 May 2016 02:29 Go to previous messageGo to next message
You can use ctrl-/ to comment with a single line comment
This works on the current line or within a block of selected lines.
To comment with a multiline comment (/* ... */) use ctrl-shift-/ but this only works on selected lines.
EDIT: I'm assuming you just want to comment code lines. I don't use java much and don't really know what ctrl+shift+j does in the java perspective.
[Updated on: Mon, 23 May 2016 08:59] by Moderator
Re: how can I Automatic commented code [message #1734302 is a reply to message #1732969] Mon, 06 June 2016 21:18 Go to previous message
thank you very much for your help.
alt+shift+j can auto creat a part of the comment with function like this
index.php/fa/26088/0/
I'am sorry.It's alt+shift+j
  • Attachment: 2.jpg
    (Size: 8.78KB, Downloaded 513 times)
[Updated on: Mon, 06 June 2016 21:19] by Moderator
Previous Topic:Launching eclipse IDE failed on ubuntu 16.04
Next Topic:Privileged container support in eclipse CDT
Current Time: Sun Jul 20 16:07:03 EDT 2025
Powered by FUDForum. Page generated in 0.03553 seconds
