Home » Modeling » M2T (model-to-text transformation) » Acceleo : How do I compare the value of the current and the previous iteration in a for loop(Acceleo )
Acceleo : How do I compare the value of the current and the previous iteration in a for loop [message #1733932] Thu, 02 June 2016 06:09 Go to next message
Is it possible to compare the value of the current and the previous iteration in a for loop in Acceleo ? Knowing that LET can be defined inside for loop but it will be mutable at each current iteration, therefore the previous value will be lost and we will get always only the current value.
Any idea guys ?
Thanks.
Re: Acceleo : How do I compare the value of the current and the previous iteration in a for loop [message #1733986 is a reply to message #1733932] Thu, 02 June 2016 12:11 Go to previous message
The pure OCL solution is to use the integer Sequence idiom
Sequence{1..N}->forAll(i : Integer | ... ->at(i) ...)
this allows you to refer to i+1/i-1 or whatever.
IIRC Acceleo has a secret "i" variable that dioes this for free. However
it is not in accord with the OMG MOFM2T specification.
Ed Willink
> the current value. Any idea guys ? Thanks.
Previous Topic:Is there a better [let] construct for multiple variable context
Next Topic:JET tag library documentation?
Current Time: Sun Jul 20 12:42:47 EDT 2025
Powered by FUDForum. Page generated in 0.03514 seconds
