Home » Eclipse Projects » Sirius » WorkspaceImage customisation does not aut-rotate when bordered node is moved
WorkspaceImage customisation does not aut-rotate when bordered node is moved [message #1732818] Fri, 20 May 2016 08:42 Go to next message
I am trying to replace the workspace image path of a bordered node in a
style customisation. It works fine, however there is a quirk that I
don't understand:
The original behavior is, that if I move the bordered node from one side
of its container, to another side, the image "auto-rotates".
With my style customisation, this behavior is lost.
I have posted a screenshot here to illustrate what I mean:
http://imgur.com/wI1gjk0
In the screenshot, the green port rotates when moving it along the edge.
My style customisation is the grey port, which does not show this
behavior. Anyone knows how to fix this?
Felix
Re: WorkspaceImage customisation does not aut-rotate when bordered node is moved [message #1733819 is a reply to message #1732818] Wed, 01 June 2016 04:23 Go to previous messageGo to next message
On 20-May-16 14:42, Felix Dorner wrote:
> don't understand:
Ok, just to close up, this autorotate feature is implemented in capella
itself. Would be a good feature for sirius though.
Felix
Re: WorkspaceImage customisation does not aut-rotate when bordered node is moved [message #1733910 is a reply to message #1733819] Thu, 02 June 2016 03:26 Go to previous messageGo to next message
>> Hi,
>> don't understand:
> Felix
This subject was discussed internally since a long time. An issue exists
in our internal bug tracker about this (before Sirius "was open-sourced").
I will create a Sirius bugzilla to reflect this internal issue and allow
to follow this subject.
Laurent Redor - Obeo
Re: WorkspaceImage customisation does not aut-rotate when bordered node is moved [message #1733911 is a reply to message #1733910] Thu, 02 June 2016 03:41 Go to previous message
The corresponding bugzilla is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=495240
>>> Hi,
>>> don't understand:
>> Felix
> Regards,
Previous Topic:Type/Style/Class not found during VSM validation
Next Topic:Converting the Ifile to modeling file
Current Time: Sun Jul 20 04:33:41 EDT 2025
Powered by FUDForum. Page generated in 0.03635 seconds
