Home » Modeling » OCL » [oclinecore] import statement gets rewritten
[oclinecore] import statement gets rewritten [message #1733733] Tue, 31 May 2016 05:57 Go to next message
I have a couple of meta models in different projects that depend on each other. I edit them using the OCLinEcore editor. Consequently, they contain an import statement like:
import sys : '../../com.wilbert.mm/model/sys.ecore#/' ;
I encountered some errors when testing my application with exceptions like:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.FileNotFoundException: ..\..\com.wilbert.mm\model\expr.ecore (The system cannot find the path specified)
       at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
       at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
       at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
       at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:220)
       at org.eclipse.ocl.pivot.internal.ecore.es2as.Ecore2AS.loadImports(Ecore2AS.java:620)
       at org.eclipse.ocl.pivot.internal.ecore.es2as.Ecore2AS.loadImports(Ecore2AS.java:583)
       at org.eclipse.ocl.pivot.internal.ecore.es2as.Ecore2AS.getASModel(Ecore2AS.java:316)
When I change the import line in something like:
import sys : 'platform:/plugin/com.wilbert.mm/model/sys.ecore#/' ;
Then even after save and reloading, the platform:/plugin URI is replaced by the URI with the relative path.
Is there a reason for this or should I consider this a bug? (If needed I can provide a 'reproduce' case.)
Greetings,
Wilbert.
Re: [oclinecore] import statement gets rewritten [message #1733735 is a reply to message #1733733] Tue, 31 May 2016 06:03 Go to previous messageGo to next message
It seems to be a clear nuisance for you, so it's probably a bug. A
Bugzilla with a simple repro, probably an exact sequence of edit
commands would be very helpful.
Ed Willink
On 31/05/2016 10:57, Wilbert Alberts wrote:
> at
> at
> at
> at
> at
> at
> at
> Greetings,
> Wilbert.
Re: [oclinecore] import statement gets rewritten [message #1733753 is a reply to message #1733735] Tue, 31 May 2016 08:47 Go to previous message
Hi Ed,
Thanks for the reply. I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=495017
Greetings,
Wilbert.
Previous Topic:Unicode support
Next Topic:Define allInstances() operation for Signals
Current Time: Sun Jul 20 07:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.02922 seconds
