Home » Modeling » Papyrus » Anyone working on C++ reverse engineering?(Looking for interested parties to developing C++ reverse engineering plugin for Papyrus)
Anyone working on C++ reverse engineering? [message #1733445] Fri, 27 May 2016 10:36 Go to next message
Is there anyone out there who has or is working on or interested in creating a C++ reverse engineering plugin for Papyrus?
I am interested in either testing or participating in the development of such a plugin. If you are have a plugin or are in the midst of development or are starting development or would like to develop said plugin reply to this posting.
Paul
Re: Anyone working on C++ reverse engineering? [message #1733556 is a reply to message #1733445] Mon, 30 May 2016 03:09 Go to previous messageGo to next message
I guess you should take a look at Papyrus Designer. As I understand, it should have support for C++ reverse engineering. Someone with more insight into this component can probably fill in.
Hope this helps,
/Peter Cigéhn
Re: Anyone working on C++ reverse engineering? [message #1733595 is a reply to message #1733445] Mon, 30 May 2016 07:07 Go to previous messageGo to next message
There is a C++ reverse feature in Papyrus Designer:
Release: http://download.eclipse.org/modeling/mdt/papyrus/components/designer/
Nightly: https://hudson.eclipse.org/papyrus/view/Designer/job/papyrus-designer-neon-papyrusnightly/ws/releng/org.eclipse.papyrus.designer.p2/target/repository/
Otherwise there are some unreleased experimental work (e.g. incremental reverse) in the repo:
https://git.eclipse.org/r/papyrus/org.eclipse.papyrus-designer
The plugins are:
- org.eclipse.papyrus.designer.languages.cpp.reverse
- org.eclipse.papyrus.designer.languages.cpp.reverse.ui
Re: Anyone working on C++ reverse engineering? [message #1733638 is a reply to message #1733445] Mon, 30 May 2016 10:59 Go to previous messageGo to next message
Hi Paul,
yes, as Peter mentioned said (thanks!), Papyrus software designer supports C++ reverse engineering. It is aligned with the upcoming Papyrus 2.0 for neon. The homepage is https://www.eclipse.org/papyrus/components/designer/.
You can install it using the update site http://download.eclipse.org/modeling/mdt/papyrus/components/designer/
Alternatively, use the git access (https://git.eclipse.org/c/papyrus/org.eclipse.papyrus-designer.git)
Documentation is lagging a bit behind (we plan a 1.0 release at the end of june), you could have a look at the plugin org.eclipse.papyrus.designer.languages.cpp.reverse.
Re: Anyone working on C++ reverse engineering? [message #1733767 is a reply to message #1733638] Tue, 31 May 2016 10:32 Go to previous messageGo to next message
Thank you all for your replies!
Unfortunately when I go to the components designer project the documentation links all return "404". I added the link to my update links and nothing happens.
Perhaps there has been a change or else the web site is being updated or is not operational? Perhaps the components designer is not applicable to either the standalone version I have installed or the plugins I have installed?
FYI:
My eclipse environment is:
Version: Mars.2 Release (4.5.2)
Build id: 20160218-0600
Re: Anyone working on C++ reverse engineering? [message #1733967 is a reply to message #1733638] Thu, 02 June 2016 10:23 Go to previous messageGo to next message
Is it possible to obtain access to the C++ reverse engineering portion of Papyrus prior to its June 22 release?
Re: Anyone working on C++ reverse engineering? [message #1745581 is a reply to message #1733967] Wed, 12 October 2016 13:06 Go to previous message
From this thread: https://www.eclipse.org/forums/index.php/t/1078835/
Shuai Li wrote on Wed, 20 July 2016 04:06
In order perform the reverse, you have to right click on the CDT project, or one of its files open in the current editor. Then you have a popup menu:
Reverse > To new UML model
or Reverse > To existing UML model (Overwrite)
Note that we have not release incremental reverse yet because it is experimental, but it is available if you get the code.
When I follow these instructions in Windows 10 using Neon, I get a confirmation window saying "Reversed to new UML model in reversed_models/ folder of MyProject", but no no output appears to actually be generated. I can't even find the folder it supposedly created to place the model. I have the Desinger-CPP component installed and otherwise have no error messages.
Previous Topic:Constraint parameters not visible
Next Topic:org.eclipse.core.commands.ExecutionException when creating Sequence Diagram
Current Time: Sun Jul 20 04:28:55 EDT 2025
Powered by FUDForum. Page generated in 0.04815 seconds
