Home » Language IDEs » Java Development Tools (JDT) » Arrays Now Break Code Check (Attempting To Use Arrays Sets Off Errors )
icon4.gif  Arrays Now Break Code Check [message #1733509] Sun, 29 May 2016 00:15 Go to next message
Version: Indigo Service Release 2
Build id: 20120216-1857
Arrays now cause bugs ...
int[] x  =  new int[5];
x[0] = 1;
Produces these errors:
Exception in thread "main" java.lang.Error: Unresolved compilation problems:
Syntax error on token ";", { expected after this token
Syntax error, insert "}" to complete ClassBody
at me.RLS0812.Testing.Test.<init>(Test.java:13)
at me.RLS0812.Testing.Main.main(Main.java:22)
http://s33.postimg.org/690jqvr1b/Eclipse_error.jpg
Re: Arrays Now Break Code Check [message #1733514 is a reply to message #1733509] Sun, 29 May 2016 06:32 Go to previous message
Rick S wrote on Sun, 29 May 2016 06:15
No, there's no bug in JDT, and it's not the array that causes the error.
You are trying to implement statements in a position where Java does not admit statements.
The first line,
is OK, this is a field declaration with initialization.
The second line,
x[0] = 1;
is a statement, this is illegal outside of method bodies and class/instance initializers. The solution is to put this statement into a new initializer, s.t. like this:
{ // this starts an instance initializer
   x[0] = 1;
I admit that the error is raised at a suboptimal location, but then note that it says: "{ expected after this token" to signal that something is syntactically wrong after the semicolon.
best,
Stephan
PS: btw, indigo is quite old, you should really consider updating to a recent version of Eclipse, you are missing out on 4 years worth of bug fixes and enhancements.
Previous Topic:Problem creation WSDL with eclipse
Next Topic:Capture action "Run Last"
Current Time: Sun Jul 20 10:49:25 EDT 2025
Powered by FUDForum. Page generated in 0.24956 seconds
