Home » Language IDEs » PHP Development Tools (PDT) » Turn on Object Oriented Editing - How To?
Turn on Object Oriented Editing - How To? [message #1733478] Fri, 27 May 2016 20:21 Go to next message
Hi, I've just downloaded and installed PDT on my Mars and it's great.
But how do I turn on the object-oriented editing help e.g. instead of typing "this -> connect" I'd like to have have PDT fill it with "this -> connect->"
At the moment, simply typing "->" generates a syntax error, unexpected '->'
Re: Turn on Object Oriented Editing - How To? [message #1733479 is a reply to message #1733478] Fri, 27 May 2016 20:44 Go to previous messageGo to next message
If you are editing a PHP file, you should be able to press CTRL-. (CTRL + period key) to put in the "->" for you. However, entering it either way works fine. Are you typing "this->connect" or "$this->connect"? You need to include the "$" (which is hard to remember when you are moving between languages).
Good luck.
Re: Turn on Object Oriented Editing - How To? [message #1733521 is a reply to message #1733479] Sun, 29 May 2016 12:26 Go to previous message
Thanks Smile
Previous Topic:problem HTML completition in .php
Next Topic:Set up RUN Configuration - How?
Current Time: Sun Jul 20 14:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.05610 seconds
