Home » Archived » Jubula » Error 7009 y 5009(7009: Test Execution Error Could not connect to Aut: la 5009: AUT start failed Establishing connection to AUT failed. Please scheck the AUT configuration)
Error 7009 y 5009 [message #1732962] Mon, 23 May 2016 09:05 Go to next message
Hello everyone.
I updated my Jubula to version 8.2 percent and have problem with some of my Test. When you open the program and run the Test I get two errors
Could not connect to Aut: the
5009: AUT failed start
I searched on the internet but I have not found anything worth me.
How you could try to solve the problem?
Re: Error 7009 y 5009 [message #1733055 is a reply to message #1732962] Tue, 24 May 2016 02:05 Go to previous messageGo to next message
Hello Pablo,
Are you working with an RCP application? Did you follow all the migration steps? If it is an RCP application, then I suspect you may not have migrated the RCP accessor (correctly).
Alex
Re: Error 7009 y 5009 [message #1733417 is a reply to message #1733055] Thu, 26 May 2016 23:19 Go to previous messageGo to next message
alexandra Thank you.
Following your advice I have looked at the information for the migration. Ahi me recomendan follow the configuration steps from the manual Jubula. I've looked all settings. I have the plug - ins azap installed, the update also config.ini file. Therefore I can not understand the problem.
Thank you.
Pablo Gallardo
Re: Error 7009 y 5009 [message #1733548 is a reply to message #1733417] Mon, 30 May 2016 02:34 Go to previous messageGo to next message
Hello Pablo!
Thanks for checking that.
You should try starting the AUT with -clean and see if it works then. If not, can you add the following information:
1. What steps are you taking to start the application? Are you starting it via the ITE or the testexec, or via autrun?
2. The AUT Agent log and RC_RCP log for the time when you start the AUT
3. Which version of Eclipse does the AUT use?
4. Can you attach an export of the project so I can see the configuration?
5. Can you attach an image of: your plugins directory with the Jubula rc.rcp plugin in it, and an image of your config.ini
Alex
Re: Error 7009 y 5009 [message #1733948 is a reply to message #1733548] Thu, 02 June 2016 07:42 Go to previous messageGo to next message
Resolved!
The main problem was that there was updated all plug-ins. We carry many side projects and have not actializado everything well. Sorry for the inconvenience and thank you very much for the time spent.
Regards!
Pablo Gallardo
Re: Error 7009 y 5009 [message #1733956 is a reply to message #1733948] Thu, 02 June 2016 08:43 Go to previous message
Glad to hear it's working now! Thanks for the update.
Alex
[Updated on: Thu, 02 June 2016 08:43] by Moderator
Previous Topic:Jubula Demo with HTML
Next Topic:How Jubula works?
Current Time: Sun Jul 20 14:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.04481 seconds
