Problem creation WSDL with eclipse [message #1733180] |
Wed, 25 May 2016 03:36  |
Hi all,
I am new of forum and i don't speak good english, sorry for this.
I tried to create a simple service , a class with one method that executes the sum of two numbers and then I created the wsdl with eclipse and deploy on tomcat . Works well.
Then I tried to create another project with another service that uses a library to extract weather information , the class code is this:
import net.aksingh.owmjapis.DailyForecast;
import net.aksingh.owmjapis.OpenWeatherMap;
import net.aksingh.owmjapis.OpenWeatherMap.Language;
public class WService {
public float getCurrentWeather(String city) throws Exception{
byte count=1;
try {
OpenWeatherMap owm = new OpenWeatherMap("accessToken");
owm.setLang(Language.ITALIAN);
DailyForecast df = owm.dailyForecastByCityName(city,count );
return df.getForecastInstance(0).getTemperatureInstance().getDayTemperature();
} catch(Exception e) {
throw new Exception(e.getMessage());
i created the wsdl and deploy on tomcat but when I try to run it on server, it returns this error message :
<?xml version="1.0" encoding="utf-8"?><soapenv:Envelope xmlns:soapenv="http:/schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="ht:/.w3.org/2001/XMLSchema" xmlns:xsi="ht:/.w3.org/2001/XMLSchema-instance"><soapenv:Body><soapenv:Fault><faultcode>soapenv:Server.userException</faultcode><faultstring>java.lang.reflect.InvocationTargetException</faultstring><detail><ns1:hostname xmlns:ns1="ht:/xml.apache.org/axis/">Alessandro</ns1:hostname></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
( i must eliminate the link to xml because is my first message on this forum )
Re: Problem creation WSDL with eclipse [message #1733221 is a reply to message #1733180] |
Wed, 25 May 2016 09:28  |
This sounds like a question better directed to the Web Tools forum
(assuming that's what you're using).
On 25.05.2016 14:58, Alessandro Siervo wrote:
> Hi all,
> byte count=1;
> try {
> return
> forum )
> Thanks
FUDForum. Page generated in 0.03506 seconds
