Home » Eclipse Projects » OM2M » OM2M using COAP Protocol(How to configure COAP binding in to eclipse IN-CSE and MN-CSE stack)
OM2M using COAP Protocol [message #1733048] Tue, 24 May 2016 01:03 Go to next message
I have gone through the basic eclipse OM2M tutorial and followed
the steps defined in the eclipse website and downloaded the IN-CSE and
MN-CSE stack and configured as per tutorial instruction. I have made
the bellow setup.
IN-CSE--- PC1
MN-CSE--PC2
Now i have started the IN-CSE and MN-CSE , MN-CSE configured
successfully on IN-CSE then i started sample programme. I can able to
control the sample program from PC1 then i captured the packet using
wireshark . Now i can see only http packet but i need to replace this
http protocol with COAP. Please help me how to configure the
configuration file so that i can able to control my remote devices
using COAP protocol and also how to link COAP binding in existing plugin.
Nithyananth
[Updated on: Tue, 24 May 2016 01:03] by Moderator
Re: OM2M using COAP Protocol [message #1740623 is a reply to message #1733048] Tue, 16 August 2016 08:17 Go to previous message
hi Nithyananth,
were you successfully in using the coap binding? If yes, can you give me a hint how to use it. Thank you so much!
Son
Previous Topic:Does OM2M support oneM2M Release 2 (i.e. Semantics)?
Next Topic:Add a new plugin in OM2M (without Eclipse)
Current Time: Sat Jul 19 07:09:04 EDT 2025
Powered by FUDForum. Page generated in 0.05532 seconds
