Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » understanding when to use converter function blocks
understanding when to use converter function blocks [message #1732465] Tue, 17 May 2016 09:47 Go to next message
I am trying to understand when there is an absolute need of using converter function blocks. I have seen use of the converter function blocks before any publish and after any subscribe (XPlus3) ; on just publish end or subscribe end (MechPress); or none at all (MechPress). Can someone please tell me when the converter function blocks need to used?
Subscribe with converter and no converter in
MechPress ManualTest Device and Simulation Resource
http://postimg.org/image/ysnierx3l/
Publish with no converter in Mechpress Control Device
and EMB_RES Resource
http://postimg.org/image/65inzh101/
MechPress
Publish with converter in XPlus3 PC_1 Device VIS Resource
http://postimg.org/image/6ukylwg9d/
Subscribe with converter in XPlus3 MICROCONTROLLER Device; CALC Resource
http://postimg.org/image/3w5m98f2p/
Re: understanding when to use converter function blocks [message #1732473 is a reply to message #1732465] Tue, 17 May 2016 10:28 Go to previous message
The rule if a converter FB is needed is as follows:
If both sides of a data connection to be connected are of an ANY type (e.g., ANY, ANY_NUM, ANY_MAGNITUDE,...) then a converter FB is needed. If one of the connection's ends has a concrete type (INT, DINT, WORD, STRING), then this type is used to typify the other side of the connection.
This is due the fact that ANY types are abstract, non-instantiable types. In order to create a valid data connection at least one end of a connection has to be a concrete type, which is then used to typify both the data connection, as well as the ANY port of an FB at runtime.
So in case of connecting an RD of a subscriber (type ANY) with an SD of a publisher (also type ANY) a converter FB has to be introduced to typify both sides of the desired connection. In case of the RD connected to the PRESS FB, the data inputs are already of a concrete type, which is used to typify the RD of the subscriber
Kind regards,
Martin
Previous Topic:Problems running FORTE in raspberry pi
Next Topic:How to test a function block in 4DIAC?
Current Time: Sun Jul 20 18:23:39 EDT 2025
Powered by FUDForum. Page generated in 0.05412 seconds
