Home » Language IDEs » ServerTools (WTP) » How to add Java EE JDK in Eclipse Mars
How to add Java EE JDK in Eclipse Mars [message #1728859] Fri, 08 April 2016 01:05 Go to next message
Eclipse allows you to select a single JDK among Java JDKs being installed on the host (Windows>Preferences >Java>Installed JRE). However, when developing a J2EE project, java code for Session and Entity bean shows many errors because Java EE JDK is not installed.
I tried adding Java EE SDK using Windows>Preferences>Java>Build Path>Classpath Variables, but it does not help. I would prefer not to instal it into the Build Path for each project.
Any suggestion?
[Updated on: Fri, 08 April 2016 08:43] by Moderator
Re: How to add Java EE JDK in Eclipse Mars [message #1732100 is a reply to message #1728859] Thu, 12 May 2016 10:59 Go to previous message
Since every Java EE server has to be able to run code against those classes, they also provide those classes. You project should be getting all of those classes from a server that you're targeting. See the help topic.
Previous Topic:err_connection_refused
Next Topic:Mars2 Runtime Environments will not find tomcat 8.0.33
Current Time: Sun Jul 20 10:27:49 EDT 2025
Powered by FUDForum. Page generated in 0.03748 seconds
