Home » Modeling » TMF (Xtext) » Disambiguate between reference and ValidID
Disambiguate between reference and ValidID [message #1731570] Fri, 06 May 2016 18:05 Go to next message
I have a point in my grammar where I would like to handle either a ValidID or a cross-reference.
However, this creates an ambiguity, as the cross-reference also relies on the RULE_ID.
Is there a good solution to this, other than inserting some kind of special token?
Here's a simple example grammar to illustrate:
Declaration:
   name=ID
Reference:
   IDReference | DeclarationReference
IDReference:
   idRef = ValidID ';'
DeclarationReference:
   declRef = [Declaration] ';'
I could just use the ValidID rule, and then internally check if such an ID matches a known declaration. If that's the best option, can do, though it'll mean losing the inherent benefits of the cross-reference system.
Re: Disambiguate between reference and ValidID [message #1731577 is a reply to message #1731570] Sat, 07 May 2016 01:03 Go to previous messageGo to next message
In case you dont know it. [Type] is Short for [Type|ID] so an ID will be used. Of Course you can change this to whatever you like e.g [Type|YourID] with YourID being a Terminal Or a datatype rule
Re: Disambiguate between reference and ValidID [message #1731578 is a reply to message #1731577] Sat, 07 May 2016 01:05 Go to previous message
Of you Reality dont Want to Cross ref you have do adapt linking.
Previous Topic:Check if EObject is fully parsed
Next Topic:Type for variable
Current Time: Sun Jul 20 03:40:58 EDT 2025
Powered by FUDForum. Page generated in 0.24386 seconds
