Error message with XML Schema Validator [message #172863] |
Tue, 04 July 2006 03:28  |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi everybody,
I have a strange problem with a dynamic web project which worked fine in WTP 1.5
RC 5.
I upgraded to 1.5, with a completely new workspace, and now the project shows
this error message:
"The validator XML Schema Validator is a delegating validator but no delegate
can found for it.".
An other web project works just fine. I did not find any difference in
".project", ".classpath", ".settings\.component" or any other settings file.
Of course there is nothing to be found in the error log.
Does anybody have an idea what could be wrong ? Currently there is too few
information to make a bugzilla report :-(.
Best regards
Wolfgang
Re: Error message with XML Schema Validator [message #173353 is a reply to message #173188] |
Thu, 06 July 2006 11:19   |
Hi Valentin,
thanks a lot, I got it working. It was much easier than you suggested: I copied
the project, changed the name, closed the original project and deleted it from
eclipse, then I imported the copy. Validation ran without problems. So i deleted
the copy, too, and re-imported the original project. Now it validates fine
again. No idea what went wrong, and of course no chance to repro it. OK, I could
try a blank eclipse installation and import my project... Seems there is a
severe problem, as you said.
Best regards
Wolfgang
Valentin Baciu wrote:
> I was wondering if you could try going to the project's
> properties/Validation then try overriding the global preferences, make sure
> the delegate validator is configured and apply the changes.
> Revalidate. Make sure you then revert to using the global preferences.
> If this does not work I suggest re-creating the project - if at all
> possible. The metadata storing the validation preferences seems to have been
> corrupted somehow.
> Valentin
Re: Error message with XML Schema Validator [message #179307 is a reply to message #173353] |
Mon, 18 September 2006 15:46  |
In case anyone else happens to encounter an "The validator XML Schema
Validator is a delegating validator but no delegate can found for it"
error in their project, I've seen this symptom occur due to:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155706
Cleaning the project appears to get rid of the error.
Larry
Wolfgang Knauf wrote:
> Hi Valentin,
> copied the project, changed the name, closed the original project and
> deleted it from eclipse, then I imported the copy. Validation ran
> without problems. So i deleted the copy, too, and re-imported the
> original project. Now it validates fine again. No idea what went wrong,
> and of course no chance to repro it. OK, I could try a blank eclipse
> installation and import my project... Seems there is a severe problem,
> as you said.
> Best regards
> Wolfgang
>> sure
>> have been
>> corrupted somehow.
>> Valentin
FUDForum. Page generated in 0.04414 seconds
