Home » Eclipse Projects » Sirius » delete element recursively
delete element recursively [message #1728215] Thu, 31 March 2016 20:03 Go to next message
I work with Containers and need a custom delete element Feature.
In my model a container can have unlimited children and these children can also have unlimited children and so on.
The Relation between a container and its child is described with a containment-element which has the features: "contained Node"(parent) and "containing Node"(child).
If I delete a parent (without delete element feature), the relating containment-element is not deleted.
So I need the custom delete Element Tool.
But here is the problem. If I want to delete a container, which contains other containers (which contains other containers and so on) I have to do it recursively... Therefore I want to use this implemented algorithm:
public void deleteContainer(EObject container){
     if(container instanceof ExampleImpl){
		ExampleImpl example = (ExampleImpl) container;
		if(!example.getChildren().isEmpty()){
			for(Containment containment : example.getChildren()){
				deleteContainer(containment.getContainedNode());
			// Delete Containment and Container
Where the comment stands, I could use the method: example.eBasicRemoveFromContainer(null), but if I do so, the deletion of a containment can not be undone.
Is there another method to delete an element, with which the deletion can be undone like the Remove-feature I can use in the odesign ?
Another way would be to use the Remove-feature, but I didn't find a way to do the recursion.
For Example I can do Change Context var:element, then If aql:self.children->notEmpty(), then For (expression: aql:self.children) child. But there is no way to put the child (or the contained node) back to the Change Context and the If - Feature. Or am I wrong?
I really hope my problem is understandable
Re: delete element recursively [message #1728651 is a reply to message #1728215] Wed, 06 April 2016 05:15 Go to previous messageGo to next message
From what I understand, you want to delete an element and all its
contained children in your EMF model?
In that case there is no need to delete recursively all its
sub-elements. Deleting an EObject means detaching it from its parent and
removing it from all the feature referencing it (see
org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject)).
If the sub-elements are displayed out of the parent container in the
diagram, they should also be deleted from the diagram automatically.
Florian - Obeo
Re: delete element recursively [message #1728652 is a reply to message #1728651] Wed, 06 April 2016 05:26 Go to previous messageGo to next message
Maybe you have references toward those sub-elements. In that case
calling org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject eObject,
boolean recursive) with recursive true will also remove sub-elements
from features referencing them.
On 04/06/2016 11:15 AM, Florian Barbin wrote:
> Hello,
> Regards,
Florian - Obeo
Re: delete element recursively [message #1729240 is a reply to message #1728652] Tue, 12 April 2016 07:02 Go to previous messageGo to next message
Florian Barbin wrote on Wed, 06 April 2016 09:26
> Hello,
> Regards,
Florian - Obeo
It doesn't work as it should.
The selected element is deleted from model and representation, but the contained elements are only removed in the representation and not in the model. The elements referencing to the selected element are not touched and stay in both, model and representation.
To explain it again. The Container-Elements are not diretly connected to each other.
The Container-elements have 2 features : children and containers.
The Containment-elements have 2 features: Contained Node and Containing Node.
For Example:
- 2 Container: father, son
- 1 Containment: parent
- Container father contains Container son
Container father.children : Containment parent
Container father.containers : -
Container son.children : -
Container son.containers: Containment parent
Containment parent.contained_node : Container son
Containment parent.containing_node : Container father
If I delete the Container father with org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject eObject,
boolean recursive) (recursive = true), the Container father is deleted from model and representation, Container son is deleted from representation. Containment parent is not deleted, only Container son is removed from the feature Containing Node.
Re: delete element recursively [message #1730510 is a reply to message #1729240] Tue, 26 April 2016 09:06 Go to previous messageGo to next message
Hi Frank,
Le 12/04/2016 13:02, Frank Sorek a écrit :
> It doesn't work as it should. The selected element is deleted from model
> representation.
> each other. The Container-elements have 2 features : children and
> containers. The Containment-elements have 2 features: Contained Node and
> Containing Node.
If those EReferences are not containment reference (check the
containment attribute in your ecore model) then there is no containment
between your EObjects and that explains your delete tool behavior and
why your children elements are not deleted.
If your model had real containment of EObject, removing the selected
EObject from its container would also remove its children from the model
as they will only be able to retrieve it by calling eContainer() but if
you call eResource() or a loop of eContainer(), it will return null.
Then for all detached object, Sirius use its inverse cross referencer
adapter to clean the model and delete all references pointing to those
detached object (as a precommit listener of the EMF transaction) to
avoid dangling references.
If you have no containment references between you parent element and
your children elements, then in your delete service, you have to
retrieve all children elements and to remove them from their container
or from the resource if they are roots of the resource.
> For Example: - 2 Container: father, son
> org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject eObject, boolean
Maxime - Obeo
Re: delete element recursively [message #1730815 is a reply to message #1730510] Thu, 28 April 2016 12:37 Go to previous message
Thanks a lot for your response,
I managed to solve the problem with a java class. I collect with my own methods all elements to be deleted and delete them afterwards with org.eclipse.emf.ecore.util.EcoreUtil.delete(EObject))
Previous Topic:Export/Generate Doc from Documentation Fields in Specification
Next Topic:Example not working
Current Time: Sat Jul 19 14:06:12 EDT 2025
Powered by FUDForum. Page generated in 0.07558 seconds
