Home » Modeling » TMF (Xtext) » How to get type of generic arguments of inferred type?
How to get type of generic arguments of inferred type? [message #1730629] Wed, 27 April 2016 04:32 Go to next message
In my dsl I want to create a field which type is a type of generic argument of an XOrExpression.
Here is a simplified example of what I want to achieve.
Using this grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	greetings+=Greeting*
Greeting:
	'test' name = ID '=' constructor = XOrExpression
For the following input:
test a = new java.util.ArrayList<Integer>()
I want to get the following generated code:
public class MyGreetings {
  private ArrayList<Integer> a = new ArrayList<Integer>();
  private Integer gen__a;
I.e. if expression is of type ArrayList<Integer> I want to create a uninitialized field of type Integer.
I use typeReferences.getArgument() call in inferrer to retrieve type arguments.
For the simplicity of an example I assume we always have one generic argument.
My inferrer looks like this:
class MyDslJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	@Inject TypeReferences typeReferences;
	def dispatch void infer(Model element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
   		acceptor.accept(element.toClass("my.company.greeting.MyGreetings")) [
   			for (greeting : element.greetings) {
   				members +=  greeting.toField(greeting.name, greeting.constructor.inferredType) [
   					initializer = greeting.constructor
				val genericsType = typeReferences.getArgument(greeting.constructor.inferredType, 0)
				members += greeting.toField("gen__" + greeting.name, genericsType)
The problem is, exception occurs when I try to access inferred type to get arguments in this line:
Here is the log of exception:
java.lang.IllegalStateException: equivalent could not be computed
	at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:83)
	at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.getEquivalent(XComputedTypeReferenceImplCustom.java:46)
	at org.eclipse.xtext.common.types.impl.JvmSpecializedTypeReferenceImplCustom.getType(JvmSpecializedTypeReferenceImplCustom.java:23)
	at org.eclipse.xtext.common.types.util.TypeReferences.getArgument(TypeReferences.java:146)
	at org.xtext.example.mydsl.jvmmodel.MyDslJvmModelInferrer.lambda$0(MyDslJvmModelInferrer.java:48)
I don't quite get why equivalent could not be computed. Without the second part my model infers successfully and I get the following:
So the type is computed ok. But somehow I cannot yet access it.
Can anyone please explain what am I doing wrong? Is it possible to achieve what I want at all?
Thanks in advance.
[Updated on: Wed, 27 April 2016 04:35] by Moderator
Re: How to get type of generic arguments of inferred type? [message #1730830 is a reply to message #1730629] Thu, 28 April 2016 15:12 Go to previous message
You receive the error because you cannot resolve types (which happens when you call getArgument, as this is an eager operation) while building the JVM model.
Did you try to implement my own InferredTypeIndicator and override getTypeReference to return the type argument? The use this in your own variant of inferredType. Not sure whether this works...
Previous Topic:How to launch web editor from eclipse?
Next Topic:Understand grammar changes to address content assist issue.
Current Time: Sat Jul 19 19:22:05 EDT 2025
Powered by FUDForum. Page generated in 0.29615 seconds
