Home » Modeling » Papyrus » Setting String attribute back to null
Setting String attribute back to null [message #1707989] Fri, 11 September 2015 05:14 Go to next message
Dear all,
When using an stereotyped element with a String tag value I don't know
how to set it to null.
Initially it has a null value, because if I run the validation and the
attribute is mandatory I get the right validation error, but if I set it
to something else I don't know to set it back to null again. Is it possible?
Best,
Víctor
Re: Setting String attribute back to null [message #1708506 is a reply to message #1707989] Thu, 17 September 2015 04:38 Go to previous messageGo to next message
In the UML Model Editor (and Ecore Editor) there is a reset default
value icon on the tool bar of the properties view. However I haven't
always found that they work for me, so I sometimes resort to XMI text
editing to be sure of what's actually defined. Only the XMI view enables
the distinction between the null and empty string to be made.
Ed Willink
On 11/09/2015 10:14, V. López wrote:
> Dear all,
> it to something else I don't know to set it back to null again. Is it
> possible?
> Best,
> Víctor
Re: Setting String attribute back to null [message #1708525 is a reply to message #1708506] Thu, 17 September 2015 06:00 Go to previous messageGo to next message
Hi Ed,
Thanks a lot, I will use this approach for my OCL testing.
However, I think it's not very suitable for the users of a profile.
Best,
Víctor
Re: Setting String attribute back to null [message #1729779 is a reply to message #1708506] Mon, 18 April 2016 22:43 Go to previous messageGo to next message
Did you find a solution to this? I have the same issue.
Re: Setting String attribute back to null [message #1729904 is a reply to message #1729779] Wed, 20 April 2016 04:09 Go to previous message
Unfortunately I didn't. What I did is changing the validation functions
to check also for empty Strings, but depending on you problem that might
not be a solution.
I do think Papyrus should support that natively.
Best,
Víctor
Previous Topic:Element-types advice after/before ordering
Next Topic:[CDO] Long running ModelSet.save may result in TimeoutException
Current Time: Sun Jul 20 17:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.07800 seconds
