Home » Newcomers » Newcomers » Installer and Java Detection
Installer and Java Detection [message #1729579] Fri, 15 April 2016 11:38 Go to next message
I am attempting to use the installer, eclipse-inst-win64.exe, downloaded (again) today after having installed Oracle Java 1.8 (u77) on my Windows 10 64-bit machine.
Without delay, it defers me to the "JRE Missing" page (http://download.eclipse.org/oomph/jre/?vm=1_1_7_0_64_0) even though Java is clearly installed on my machine. I am hoping that I do not have to install Java 1.7 for some reason as that would seem odd but I'm open to any suggestions!
Thanks.
Re: Installer and Java Detection [message #1729582 is a reply to message #1729579] Fri, 15 April 2016 12:05 Go to previous messageGo to next message
It's possible that you have a 32-bit JRE installed. Open a Command Prompt window, move to the directory where the java.exe is, and run it with the -d64 switch to test if it is really 64-bit.
Re: Installer and Java Detection [message #1729591 is a reply to message #1729582] Fri, 15 April 2016 13:10 Go to previous message
Well of course it was that simple.
[sighs]
Downloaded and installed the 64-bit Java and re-ran the installer. Eclipse now installed.
Thanks!
[Updated on: Fri, 15 April 2016 13:11] by Moderator
Previous Topic:Trouble getting Eclipse to run
Next Topic:JFrame.add() will not accept JButton
Current Time: Sat Jul 19 20:06:15 EDT 2025
Powered by FUDForum. Page generated in 0.07495 seconds
