Home » Newcomers » Newcomers » Eclipse upgrade from 3.8.2 to 4.5.2(Eclipse upgrade from 3.8.2 to 4.5.2)
Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729417] Wed, 13 April 2016 23:31 Go to next message
HI
I am trying to upgrade my component from eclipse SDK 3.8.2 to 4.5.2. I had to fix various build errors after that I tried to launch my application. I am getting following error when I am running my component.
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.1.100.v20150423-1455 [786]" could not be resolved. Reason: Missing Constraint: Import-Package: org.osgi.framework.namespace; version="1.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1328)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1312)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:324)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1130)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Any help is appreciated
Re: Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729430 is a reply to message #1729417] Thu, 14 April 2016 02:52 Go to previous messageGo to next message
Have you tried to invoke "Validate Plug-ins" on your launch
configuration's Plug-ins tab?
On 14.04.2016 05:31, DEEPALI KARLEKAR wrote:
> HI I am trying to upgrade my component from eclipse SDK 3.8.2 to
> component.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729452 is a reply to message #1729430] Thu, 14 April 2016 05:29 Go to previous messageGo to next message
yes.. It says the same thing. Not that helpful
Re: Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729464 is a reply to message #1729452] Thu, 14 April 2016 06:24 Go to previous messageGo to next message
So clearly you need to fix the launch configuration. Unless you take
some initiative to do that, I'll keep asking you questions. What does
your "Launch with:" specify on that tab? If you've manually selected
things, you'll probably need to revisit that (and use the Add Required
Plug-ins button). If it's not manually done, what is in your target
platform? What have you don't to update it?
Re: Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729524 is a reply to message #1729464] Fri, 15 April 2016 02:13 Go to previous messageGo to next message
I am launching this as an eclipse application.
I was able to understand the problem. Its with osgi plugin. But now when I am updating my org.eclipse.osgi3.8 jar to org.eclipse.osgi_3.10.102.v20160118-1700, I am getting compatibility issues.
[Updated on: Fri, 15 April 2016 02:14] by Moderator
Re: Eclipse upgrade from 3.8.2 to 4.5.2 [message #1729538 is a reply to message #1729524] Fri, 15 April 2016 04:34 Go to previous message
Your latest post doesn't contain a question. Nor does it answer my
questions.
> issues.
Previous Topic:how to stop the debugger?
Next Topic:Eclipse starts in debug mode
Current Time: Sun Jul 20 09:59:42 EDT 2025
Powered by FUDForum. Page generated in 0.09498 seconds
