Home » Newcomers » Newcomers » Win Xp. Filed to create Java Virtual Machine
Win Xp. Filed to create Java Virtual Machine [message #1728727] Wed, 06 April 2016 13:22 Go to next message
Hi.
I've just installed
jdk-7u79-windows-i586.exe
and ecstracted EclipsePHP
and added the path on "ambient variables" referred to the directory where I 've installed JDK.
on my pc with Windows XP
Whem I try to open eclipse, it appears a windows with message: "Filed to create Java Virtual Machine "
What Can I do?
thanks a lot.
[Updated on: Wed, 06 April 2016 13:32] by Moderator
Re: Win Xp. Filed to create Java Virtual Machine [message #1728729 is a reply to message #1728727] Wed, 06 April 2016 13:45 Go to previous messageGo to next message
Which download of "EclipsePHP" was that? Also, Oracle does not list Windows XP among the supported platforms for JDK7.
Re: Win Xp. Filed to create Java Virtual Machine [message #1728731 is a reply to message #1728729] Wed, 06 April 2016 13:52 Go to previous messageGo to next message
I've downloaded 32 bit version for Windows
from here https://eclipse.org/pdt/#download
Jkd8 advised me with a windows where it says: "it doesn't work well with your Windows. Upgrade it"
while JKD7 installed well withouth message
EDIT: I've just solved my problem:
I've changed the two last memory value of file "eclipse.ini":
-Xms256m
-Xmx512m
eclipse RUNS
thanks a lot
[Updated on: Fri, 08 April 2016 05:08] by Moderator
Re: Win Xp. Filed to create Java Virtual Machine [message #1728884 is a reply to message #1728731] Fri, 08 April 2016 05:03 Go to previous message
I have another problem:
eclipse closes by itself.
[Updated on: Fri, 08 April 2016 05:09] by Moderator
Previous Topic:Export/import project with linked source in eclipse
Next Topic:Save/Export Syntax Colors + all settings
Current Time: Sun Jul 20 18:21:08 EDT 2025
Powered by FUDForum. Page generated in 0.08605 seconds
