Home » Eclipse Projects » Eclipse 4 » Define Key Binding in Fragment(E4 RCP application. Eclipse Keppler)
Define Key Binding in Fragment [message #1709136] Thu, 24 September 2015 08:09 Go to next message
I am trying to define a key binding for an e4 fragment. I tried to add the following model fragment:
Element ID=org.eclipse.e4.ide.application
Featurename=bindingContexts
But unfortunately this produces an exception at application start. If I add the binding context as a child to a binding context of the application plug-in, it works.
What could I be doing wrong? Here is the stack trace:
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. my-application.bindingcontext.myKeyBindings
	at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
	at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
	at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:37)
	at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
	at java.util.TimSort.countRunAndMakeAscending(Unknown Source)
	at java.util.TimSort.sort(Unknown Source)
	at java.util.Arrays.sort(Unknown Source)
	at java.util.ArrayList.sort(Unknown Source)
	at java.util.Collections.sort(Unknown Source)
	at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
	at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:90)
	at org.eclipse.e4.ui.bindings.internal.BindingTableManager.addTable(BindingTableManager.java:50)
	at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBindingTable(BindingProcessingAddon.java:165)
	at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.defineBindingTables(BindingProcessingAddon.java:151)
	at org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon.init(BindingProcessingAddon.java:100)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:267)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:49)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:276)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:144)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Re: Define Key Binding in Fragment [message #1722346 is a reply to message #1709136] Thu, 04 February 2016 04:02 Go to previous messageGo to next message
I'm having the same issue when defining a BindingContext in fragment.e4xmi. I tried with the following approaches:
Extended Element ID : org.eclipse.e4.legacy.ide.application
Feature Name : bindingContexts
and
Extended Element ID : org.eclipse.ui.contexts.dialogAndWindow
Both of these produce the same stack trace than above. Is it even possible to define a BindingContext in a fragment?
Re: Define Key Binding in Fragment [message #1728882 is a reply to message #1709136] Fri, 08 April 2016 05:01 Go to previous messageGo to next message
i can see that this thread is already a few month old but i'm having the exact same issue here as well. Are there any answers or new information on this topic yet? Help would be appreciated as i've tried a lot of things already.
Re: Define Key Binding in Fragment [message #1739479 is a reply to message #1709136] Tue, 02 August 2016 05:45 Go to previous messageGo to next message
If you want to define a new BindingContext you have to add it to the rootContext of the application. The feature bindingContext defines the active contexts in that container (defined in MBindings). Took me also some hours to find that field.
[Updated on: Tue, 02 August 2016 05:46] by Moderator
Re: Define Key Binding in Fragment [message #1760498 is a reply to message #1739479] Thu, 27 April 2017 13:54 Go to previous message
Here are the steps I took to solve this problem:
First, in the Application.e4xmi file, add a Binding Context as a Subcontext to one of the predefined Binding Contexts. (I created a Subcontext of org.eclipse.ui.context.window (In Windows))
Then, do the following in the fragment.e4xmi file:
  • Add a model fragment with Extended Element ID == <Subcontext ID from Application.e4xmi> and Feature Name == children
  • Under this children model fragment, create a Binding Context
  • Add a model fragment with Extended Element ID == org.eclipse.e4.ide.application and Feature Name == bindingTables
  • Under this bindingTables model fragment, create a Binding Table with the Binding Context ID created in the children model fragment
  • Under this Binding Table, add key bindings
Lastly, in the part descriptor of the fragment.e4xmi file, add the Binding Context from the children model fragment to the Binding Contexts list.
Previous Topic:Word wrap missing in 4.7?
Next Topic:How to use 'BeanProperties' without warnings
Current Time: Sun Jul 20 04:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.04426 seconds
