Home » Modeling » EMF » Coupled evolution problem
Coupled evolution problem [message #1727482] Wed, 23 March 2016 06:35 Go to next message
I have an Eclipse RCP application that uses EMF and relies on Java classes generated from several Ecore models. These Ecore models have recently been modified, implying that instances of the old Ecore models can no longer be opened in the application. The old instance models have to be migrated so that they conform to the new version of the Ecore models. In other words, this is a coupled evolution problem.
My current approach is to use the EMF Reflection API and Persistence API to evolve the old models. I need the Reflection API because at runtime I only have access to the new version of the generated Java classes, so I just use reflection to navigate through the old models.
However, I have hit a setback when trying to load a model conforming to the old metamodel into a Resource. Namely, I have something like the following code snippet:
String pathToOldModel = ...
URI oldModelURI = URI.createFileURI(pathToOldModel);
Resource oldModelResource = resourceSet.createResource(oldModelURI);
oldModelResource.load(null);
At this point, the call to load(null) throws the following exception:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'oldFeature' not found.
I presume this is because the Resource is attempting to use the updated Ecore model to load the old instance model, and feature 'oldFeature' does not exist in the updated Ecore model.
So, finally, my questions:
  • Do I need to provide the old Ecore models to the Resource (or ResourceFactory)?
  • If so, how can I do that?
Thanks in advance!
Vlad
Re: Coupled evolution problem [message #1727761 is a reply to message #1727482] Sat, 26 March 2016 20:25 Go to previous messageGo to next message
Vlad,
Comments below.
On 23.03.2016 18:35, Vlad Acretoaie wrote:
You might look into https://www.eclipse.org/edapt/
> ResourceFactory)?
The resource set has a package registry. So you could load the old
*.ecore, extract the EPackage from that resource, register it in the
resource set's package registry. Google "Dynamic EMF" and you should
find some examples.
> Thanks in advance!
> Cheers,
> Vlad
Re: Coupled evolution problem [message #1728421 is a reply to message #1727761] Mon, 04 April 2016 05:50 Go to previous messageGo to next message
Dear Ed,
Thank you for your answer. I have indeed looked at Edapt, but found very little documentation on using it programmatically, so decided against using it for now.
I understand your proposed solution, but am not sure what you mean by "extract the EPackage from that resource". Is there a way to get an instance of EPackage from a Resource?
I did look up Dynamic EMF (also read the relevant section from EMF the book), and as far as I understand, it is necessary that the xsi:schemaLocation attribute is set in the Ecore file in order for the Package to be registered automatically with the ResourceSet. However, this attribute is not set in the Ecore files I am working with, so I will have to register the Package manually.
Vlad
Re: Coupled evolution problem [message #1728427 is a reply to message #1728421] Mon, 04 April 2016 06:07 Go to previous messageGo to next message
Vlad,
Comments below.
On 04.04.2016 11:51, Vlad Acretoaie wrote:
> Dear Ed,
If you load a *.ecore resource the one root object in
Resource.getContents() will be an EPackage...
Yes, for it to automatically find the dynamic package.
You mean in your instance files.
Yes, you would need to manually load the *.ecore resource with the old
representation of your model into a resource set, register that
resource's EPackage in the resource set's package registry, and then
when you load an instance resource into that resource set, it will use
the older dynamic presentation of your model to represent the instance.
You could then use reflection to extract the old information (reflection
using the old EPackage) and create an instance of the new model.
> Cheers,
> Vlad
Re: Coupled evolution problem [message #1728459 is a reply to message #1728427] Mon, 04 April 2016 09:47 Go to previous messageGo to next message
Dear Ed,
Thank you for the advice. The approach you suggest seems to be working - I was able to register the EPackage exactly as you described. I am thus no longer seeing the previous "Feature not found" error message.
However, it seems I am running into another problem, which I suspect may have something to do with the particular model I am trying to load. Namely, calling load(null) on my Resource throws a NullPointerException. The stack trace shows that the exception is thrown at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFeatureType(XMLHandler.java:2193).
Do you have any idea what this could mean?
Vlad
Re: Coupled evolution problem [message #1728465 is a reply to message #1728459] Mon, 04 April 2016 10:20 Go to previous messageGo to next message
Vlad,
Does the *.ecore you're loading have references to other Ecore models?
It seems likely that some feature reference a type and that this proxy
fails to resolve.
Note that if the *.ecore references other *.ecore resource, it will be
important that you load it using an absolute URI such that all the
referenced resources resolve properly.
On 04.04.2016 15:47, Vlad Acretoaie wrote:
> Dear Ed,
> thrown at
> Cheers,
> Vlad
Re: Coupled evolution problem [message #1728469 is a reply to message #1728465] Mon, 04 April 2016 11:05 Go to previous messageGo to next message
Dear Ed,
Yes, you are right. I am loading several .ecore files, and some of them contain references to some of the others. These references were expressed using relative paths that became erroneous when I moved the .ecore files. After updating the relative paths, the NullPointerException no longer appears.
Right now I am using URI.createPlatformPluginURI(...) to get the URIs of the *.ecore resources to be loaded. I plan to distribute the old versions of my Ecore models together with my application (as part of a plugin, simply stored as any other files distributed with that plugin). Would this approach allow references to be resolved properly?
Vlad
[Updated on: Tue, 05 April 2016 03:59] by Moderator
Re: Coupled evolution problem [message #1728510 is a reply to message #1728469] Tue, 05 April 2016 02:48 Go to previous messageGo to next message
Vlad,
Comments below.
On 04.04.2016 17:05, Vlad Acretoaie wrote:
> Dear Ed,
Relative paths are not in and of themselves a problem, but keeping the
resources in relatively the same location is important.
Yes, if everything is in the workspace originally then all resources are
loaded with platform:/resource/<project-name>/<path>. As such, all
serialized cross references are relative of the form
.../<more-..>/<project-name>/<path>. If the project-name and the
plugin-in are the same (which is general the practice), then loading a
resource with platform:/plugin/<plugin-in>/<path> will result in all
relative cross references normalizing to platform:/plugin.
> Cheers,
> Vlad
Re: Coupled evolution problem [message #1728528 is a reply to message #1728510] Tue, 05 April 2016 03:59 Go to previous messageGo to next message
Hi Ed,
Thank you for the explanation. I think the setup I have now should allow cross-references to be resolved properly.
However, I am now seeing several errors of the following form:
Value 'org.eclipse.emf.ecore.impl.DynamicEObjectImpl@77b987f3 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@3c6c87fa (name: MyName) (instanceClassName: null) (abstract: false, interface: false))' is not legal.
Could it be the case that the Resource loading process is somehow trying to use generated Java classes that no longer correspond with my old .ecore files (whose EPackages I registered with the ResourceSet following your advice above)?
Vlad
Re: Coupled evolution problem [message #1728535 is a reply to message #1728528] Tue, 05 April 2016 05:01 Go to previous messageGo to next message
Vlad,
Comments below.
On 05.04.2016 09:59, Vlad Acretoaie wrote:
> Hi Ed,
> legal.
Set a breakpoint in
org.eclipse.emf.ecore.xmi.impl.XMLHandler.error(XMIException) to see
when/where/why this is happening.
Certainly you'll want to be sure that the loading process is uniformly
using your dynamic models and not any of the generated models. One
approach to ensure that is to set a breakpoint in
org.eclipse.emf.ecore.impl.XyzFactoryImpl.create(EClass)
for each of your generated factories to be sure that none of them are
being used during loading. If one is being used, you should make sure
that the corresponding dynamic EPackage is loaded and registered.
> Cheers,
> Vlad
Re: Coupled evolution problem [message #1728560 is a reply to message #1728535] Tue, 05 April 2016 09:04 Go to previous message
Hi Ed,
Thank you for the tip about setting a breakpoint in
This led me to find that one of the generated factories was used during loading due to a spelling error I had made when registering the corresponding Package in the ResourceSet (I misspelled a namespace URI).
I am now able to dynamically load models conforming to my old Ecore metamodels. Thanks a lot for the help with this.
Vlad
Previous Topic:[xcore] Error on referring imported xcore classes
Next Topic:IFileStore for my EMF Resource
Current Time: Sun Jul 20 19:54:34 EDT 2025
Powered by FUDForum. Page generated in 0.03708 seconds
