Home » Eclipse Projects » NatTable » Sorting a tree table
Sorting a tree table [message #1728355] Sun, 03 April 2016 08:10 Go to next message
I have a tree table with a max depth of 1 (0 and 1).
The data structure is like that:
IPeak
  \_ IIon
  \_ IIon
  \_ ...
IPeak extends IIon.
I use the following TreeFormat:
public class PeakTreeFormat implements TreeList.Format<IIon> {
	public boolean allowsChildren(final IIon element) {
		final boolean result = element instanceof IPeak;
		return result;
	public Comparator getComparator(final int depth) {
		// path 0 is peak, path 1 ion
		return (o1, o2) -> {
			final IPeak i1 = (IPeak) o1;
			final IPeak i2 = (IPeak) o2;
			// TODO: I need to know on which column we are sorting
                return 0;
		// return null;
	public void getPath(final List path, final IIon element) {
		if (element instanceof IPeak) {
		} else {
			if (element.getPeak() != null) {
				path.add(element.getPeak());
		path.add(element);
Sorting is working in principle, but the problem is, that it is working only on path level 1, path level 0 is ignored.
All elements on path level 1 are sorted correctly, but they don't stay "together" with all the other elements that have the same parent.
for each element on path level 1, the corresponding element on level 0 is added, leading to duplicates and broken "element groups".
In the end, I "just" want to achive an ordering first on elements on level 0, then level 1.
How can I do that?
[Updated on: Sun, 03 April 2016 10:12] by Moderator
Re: Sorting a tree table [message #1728393 is a reply to message #1728355] Mon, 04 April 2016 03:07 Go to previous messageGo to next message
Try to use the forum search function. There are already several topics on how to sort a tree. And of course our tree example also covers that.
https://www.eclipse.org/forums/index.php?t=msg&th=489524
Re: Sorting a tree table [message #1728420 is a reply to message #1728393] Mon, 04 April 2016 05:50 Go to previous message
Thanks for the hint!
I understand the problem is the custom comparator.
In your example, you use the
GlazedLists.beanPropertyComparator
, nevertheless I need to implement a custom one, since the sorting depends also on the type of element.
How can I tell the comparator on which column sorting is happening?
	final IIon i1 = (IIon) o1;
	final IIon i2 = (IIon) o2;
	if(i1 instanceof IPeak && i2 instanceof IPeak){
		// sort on different property
        return 0;
	// return null;
EDIT:
Its working now, but I don't really understand why.
I use
GlazedLists.beanPropertyComparator(IIon.class, "mz");
as described in the TreeGridExample.
I pass only one valid String property, nevertheless sorting seems to work for all columns.
[Updated on: Mon, 04 April 2016 06:20] by Moderator
Previous Topic:Frequent calls of DisplayConverter
Next Topic:[Resolved] Empty vertical Scrollbar is shown.
Current Time: Sun Jul 20 15:34:39 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
