Why does one Eclipse instance think a particular workspace's .metadata folder is read-only? [message #1728316] |
Fri, 01 April 2016 17:34  |
I'm running on CentOS7.2. I have a handful of different Eclipse installations, along with workspaces I used with those installations. I use a separate Eclipse installation for the workspace just to ensure they are independent (if you were wondering).
I'm often running multiple instances of these at the same time.
Today I noticed that when I tried to open one of the workspaces I was working with yesterday, it says 'Internal error: The folder "<workspacelocation>/.metadata" is read-only.' I've been using several of the other workspaces, and I haven't seen this problem.
This is very odd. I just compared the perm bits of this particular .metadata folder with the perm bits for a workspace that I'm not having this problem with, and they are identical. I also tried creating both a file and a folder in that location, from outside of Eclipse, and it worked fine.
When I first saw this and couldn't figure it out, I closed everything down and rebooted, and started up that instance as my first operation. Same error.
Any ideas why this might be happening?
Re: Why does one Eclipse instance think a particular workspace's .metadata folder is read-only? [message #1728323 is a reply to message #1728316] |
Fri, 01 April 2016 20:15   |
> worked fine.
> Same error.
But, you didn't attempt to open workspace from an instance of Eclipse
that another instance of Eclipse already had open, right?
FUDForum. Page generated in 0.08065 seconds
