Home » Newcomers » Newcomers » Redirect console to file
Redirect console to file [message #889417] Tue, 19 June 2012 04:05 Go to next message
I have seen that it is possible to redirect the console output to a file (Run Configuration > Common > Standard Input and Output).
What I like to have is a redirect to a file named FILENAME_<timestamp>.log. So the question is, how can I add the current timestamp to the filename?
Thanks & Best regards,
Martin
Re: Redirect console to file [message #895093 is a reply to message #889417] Wed, 11 July 2012 12:37 Go to previous messageGo to next message
Currently there is no way to do this, although I could envision using a variable to be able to insert such a value.
I opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=384844 for this enhancement. Once fixed you would be able to add a file name like FILENAME_${current_time}.log and debug you insert the value for you automatically.
Thanks for the great idea Martin!
Re: Redirect console to file [message #895119 is a reply to message #889417] Wed, 11 July 2012 14:11 Go to previous messageGo to next message
Michael,
to my shame I have to admit that I forgot this topic in the meanwhile.
I have implemented a dynamic variable for the timestamp already and use this every day. I will add the source code to the 'bug', you have created.
--Martin
Re: Redirect console to file [message #1727862 is a reply to message #895119] Mon, 28 March 2016 13:04 Go to previous message
Thank You Martin,
I have eclipse Mar 2 package, which has variable name called current_date and the format of this is YYYYMMDD_HHMI. This is very cool feature for debugging without worrying about manual rotation of log files.
Appreciate your help.
Previous Topic:Error while installing Angularjs plugin
Next Topic:Websockets and firewalls
Current Time: Sun Jul 20 18:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.07221 seconds
