Home » Eclipse Projects » Eclipse 4 » E4LifeCycle.java created by Wizard has errors
E4LifeCycle.java created by Wizard has errors [message #1727652] Thu, 24 March 2016 15:42 Go to next message
Is the bellow sequence wrong? Or is there a bug in the Wizard? Are there manual step to get around these issues?
index.php/fa/25409/0/
  • Attachment: 1.png
    (Size: 752.37KB, Downloaded 479 times)
Re: E4LifeCycle.java created by Wizard has errors [message #1727657 is a reply to message #1727652] Thu, 24 March 2016 16:29 Go to previous messageGo to next message
Do you have a target definition enabled?
Re: E4LifeCycle.java created by Wizard has errors [message #1727671 is a reply to message #1727657] Thu, 24 March 2016 19:08 Go to previous messageGo to next message
Yes
index.php/fa/25418/0/
  • Attachment: Snap1.png
    (Size: 66.08KB, Downloaded 658 times)
Re: E4LifeCycle.java created by Wizard has errors [message #1727679 is a reply to message #1727671] Fri, 25 March 2016 03:13 Go to previous messageGo to next message
I'm a bit confused about what you are trying to create. An e4 application based on SWT or an e4 application based on JavaFX. And which versions of Eclipse and efxclipse do you use? IIRC efxclipse does not support Mars 4.5.2 because it brought up a breaking change regarding SWT dependencies from the e4 side (which is wrong and will be fixed, although not sure when)
If you want to create an e4 JavaFX application I suggest to use the efxclipse wizards.
Re: E4LifeCycle.java created by Wizard has errors [message #1727681 is a reply to message #1727679] Fri, 25 March 2016 04:07 Go to previous message
Dirk is right. What you are doing is creating an e4 application who uses
SWT but your target only holds the e(fx)clipse runtime hence it can not
work.
Tom
> efxclipse wizards.
Previous Topic:80 errors creating new Eclipse4 application
Next Topic:Using File oriented editors and package explorer in e4
Current Time: Sun Jul 20 06:26:39 EDT 2025
Powered by FUDForum. Page generated in 0.03737 seconds
