Home » Newcomers » Newcomers » What does "exclamation mark" (!) mean on xubuntu eviroment? Eclipse program.
What does "exclamation mark" (!) mean on xubuntu eviroment? Eclipse program. [message #1727488] Wed, 23 March 2016 06:58 Go to next message
Hi fellows.
I wanted to know what does the exclamation mark mean?
For example:
while(!try(second)) ..
Does it refer to any previous used information on my code?
Thanks.
Re: What does "exclamation mark" (!) mean on xubuntu eviroment? Eclipse program. [message #1727496 is a reply to message #1727488] Wed, 23 March 2016 07:15 Go to previous messageGo to next message
Am 23.03.2016 um 12:03 schrieb Patrizia De Beneetis:
> Hi fellows.
> For example:
In the absence of any context information I can only suspect that it refers to the boolean NOT operator, which turns
true into false and false into true.
Cheers
/Eike
http://www.esc-net.de
Re: What does "exclamation mark" (!) mean on xubuntu eviroment? Eclipse program. [message #1727528 is a reply to message #1727488] Wed, 23 March 2016 10:30 Go to previous message
On 03/23/2016 05:03 AM, Patrizia De Beneetis wrote:
> Hi fellows.
> For example:
> Thanks.
This has nothing to do with XUbuntu. It's a language construct in C/C++
and Java (you give no context). You're learning to write code using
Eclipse? Such language-oriented question are better posted in forums
like javaranch.com and stackoverflow.com. Ask questions here about how
to download, install, set up and use Eclipse.
Best of luck!
Previous Topic:error "Java was started but returned exit code=-8053069"
Next Topic:How do I change highlighting of C++ preprocessor directives?
Current Time: Sun Jul 20 07:27:10 EDT 2025
Powered by FUDForum. Page generated in 0.07576 seconds
