Home » Eclipse Projects » Virgo » 100% brand new Virgo 3.6.4 will not start.(100% brand new Virgo 3.6.4 will not start.)
100% brand new Virgo 3.6.4 will not start. [message #1727363] Tue, 22 March 2016 08:47 Go to next message
I followed the instruction at this (https://wiki.eclipse.org/Virgo/Community/Spin) wiki page.
I use WinZip 14.5 Pro to unzip the file.
I am on Windows 7 SP 1.
I unzipped the file to c:\virgo
I created this small startup script virgo364_start.bat
SETLOCAL
DOSKEY
SET JAVA_HOME=C:\Program Files\Java\jre1.8.0_73
SET SERVER_HOME=C:\virgo
C:
cd %SERVER_HOME%
bin\startup.bat
PAUSE
REM
ENDLOCAL
I get the following errors. I have search Google and this forum but have not found a solution.
C:\virgo>bin\startup.bat
The system cannot find the path specified.
WARNING: jmxPermissions.vbs did not update the permissions of C:\virgo\configuration\org.eclipse.virgo.kernel.jmxremote.access.properties. Check the file has the correct permissions.
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727375 is a reply to message #1727363] Tue, 22 March 2016 10:13 Go to previous messageGo to next message
Hi Paul,
seems you've hit the "problem with file permissions on some variants of Windows".
Please see the section "Microsoft Windows - Troubleshooting Security Permissions" in our Virgo User Guide: https://www.eclipse.org/virgo/documentation/virgo-documentation-3.6.4.RELEASE/docs/virgo-user-guide/html/ch04s04.html.
florian
[Updated on: Tue, 22 March 2016 10:15] by Moderator
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727383 is a reply to message #1727375] Tue, 22 March 2016 10:53 Go to previous messageGo to next message
unfortunately that did not fix the issue.
index.php/fa/25378/0/
  • Attachment: Snap1.jpg
    (Size: 467.77KB, Downloaded 1191 times)
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727459 is a reply to message #1727383] Wed, 23 March 2016 05:11 Go to previous messageGo to next message
Your screenshot shows "Administrator" in "Group or user names".
Did you try to "Remove all groups and users from the list and select 'Apply'."?
I have no Windows 7 at hand, but I think it should be empty like in the documentation screenshot: https://www.eclipse.org/virgo/documentation/virgo-documentation-3.6.4.RELEASE/docs/virgo-user-guide/html/images/install-windows-2-SecuritySettings.png
[Updated on: Wed, 23 March 2016 05:12] by Moderator
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727500 is a reply to message #1727459] Wed, 23 March 2016 07:30 Go to previous messageGo to next message
Same issue.
index.php/fa/25387/0/
  • Attachment: Snap1.png
    (Size: 196.83KB, Downloaded 944 times)
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727512 is a reply to message #1727500] Wed, 23 March 2016 08:24 Go to previous messageGo to next message
I just tested same set-up on my Windows 7 as Paul mentioned it here. Although, I get the same Warning message at the very beginning of the start-up Virgo starts up successfully. I think the root cause is something else which causes Virgo not to start.
Paul, can you please set the JAVA_HOME as described in the User Guide https://www.eclipse.org/virgo/documentation/virgo-documentation-3.6.4.RELEASE/docs/virgo-user-guide/html/ch04s04.html? After doing that I would recommend to log-out of the system and log-in again, just to be sure. And then try to start Virgo again using the start-up script from Virgo itself
Re: 100% brand new Virgo 3.6.4 will not start. [message #1727535 is a reply to message #1727512] Wed, 23 March 2016 11:03 Go to previous message
Still does not work. I am going to give up on it for now. Later when I get a Unix server I will try it there.
Thanks for you time.
index.php/fa/25389/0/
  • Attachment: Snap2.png
    (Size: 151.35KB, Downloaded 807 times)
Previous Topic:VIRGO Server consumes 100% CPU Usage
Next Topic:Virgo Tutorial
Current Time: Sun Jul 20 09:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.04092 seconds
