Home » Eclipse Projects » RCP Testing Tool » RCPTT for Neon Based RCP does not work
icon9.gif  RCPTT for Neon Based RCP does not work [message #1726959] Thu, 17 March 2016 13:32 Go to next message
I'm doing some UI test for an RCP that is based in NEON M5, when I create the application within RCPTT an error message is shown: Problems occurred getting the plug-ins in this container.
Does RCPTT supports this neon version? if it doesn't, when will the support be available?
Re: RCPTT for Neon Based RCP does not work [message #1727219 is a reply to message #1726959] Mon, 21 March 2016 07:59 Go to previous messageGo to next message
Nightly builds should work fine. I will check ASAP.
At least it was some commits for support 4.6.
It should be included in 2.1 M6, it will be in few days.
Andrey.
Re: RCPTT for Neon Based RCP does not work [message #1727723 is a reply to message #1727219] Fri, 25 March 2016 14:44 Go to previous messageGo to next message
Just updated 2.1 snapshots to work properly with 4.6 and actually migrated to use of Neon for RCPTT runner and RCP app.
So feel free to try.
Be aware it now require Java 1.8.
Andrey.
Re: RCPTT for Neon Based RCP does not work [message #1728083 is a reply to message #1727723] Wed, 30 March 2016 16:51 Go to previous message
Hi andrew thanks for the reply, I'm using the version Nightly as you said and it totally works, I have one issue though, when I record "Selecting a value withing a table" it works fine, but when I replay that action it says the "combo '[]' couldn't be found. Do you have any idea if is an existing bug?
Previous Topic:Preferences Context with proxy settings not working
Next Topic:I cannot set a text value
Current Time: Sun Jul 20 07:25:44 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
