Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Edapt] Modifying an existing operation
[Edapt] Modifying an existing operation [message #1725766] Mon, 07 March 2016 08:45 Go to next message
I am currently becoming familiar with Edapt, and am facing some issues that I think may affect my productivity when writing larger migrations.
The most important of these is the fact that operations cannot be edited once they have been created. Thus, if I make a mistake when creating an operation, it seems that the only option is to delete the operation and create a new one. However, sometimes this is not possible because the effect of the deleted operation is not "undone" in the model, so adding a new operation often breaks my model's conformance to its metamodel. Am I doing something wrong here? Is it in fact possible to edit existing operations?
Thanks in advance.
Vlad
Re: [Edapt] Modifying an existing operation [message #1725781 is a reply to message #1725766] Mon, 07 March 2016 10:16 Go to previous messageGo to next message
there is no option to edit existing operations. However there is a better option than simply deleting the operation. When you right click the operation you can select "Edapt -> Undo Changes" in the context menu. This will remove it from the history and will make sure that the model is fine as well.
Johannes
Re: [Edapt] Modifying an existing operation [message #1725783 is a reply to message #1725781] Mon, 07 March 2016 10:27 Go to previous messageGo to next message
Hi Johannes,
Thank you for the quick reply. This should indeed help.
Also on the topic of productivity: I would like to programmatically invoke the migration specification from an existing application (an Eclipse plugin). I can kind of figure out how to do this based on the library example, but having a JavaDoc for the API calls would help a lot. Is such a public API available? (I can't seem to find it myself).
Vlad
Re: [Edapt] Modifying an existing operation [message #1726097 is a reply to message #1725783] Wed, 09 March 2016 10:05 Go to previous messageGo to next message
That's something I wanted to set up for a while now and finally came around to do so. The ApiDocs for the 1.1.1 release is available from here:
http://download.eclipse.org/edapt/releases/11x/111/apidocs/
Cheers
Re: [Edapt] Modifying an existing operation [message #1726101 is a reply to message #1726097] Wed, 09 March 2016 10:26 Go to previous message
Hi Johannes,
This is very helpful. Thank you very much for taking the time to do it.
Vlad
Previous Topic:[EMF Forms] nested attributes in table control
Next Topic:[EMF Forms] Collapsible group in e4 application
Current Time: Sun Jul 20 07:51:52 EDT 2025
Powered by FUDForum. Page generated in 0.04199 seconds
