Babel update site resetting the TCP connection when downloading the artifacts [message #1725918] |
Tue, 08 March 2016 08:55  |
I have very weird behaviour of Maven build, which is downloading some artifacts from the Babel repository with Tycho.
The Maven build fails randomly with errors like the one below, on one of the following artifacts (the list is not complete):
- org.eclipse.core.contenttype.nl_de
- org.eclipse.core.databinding.beans.nl_de
- http://www.eclipse.org/downloads/download.php?file=/technology/babel/update-site/R0.10.1/helios/&format=xml&countryCode=gb&timeZone=2&format=xml
During the analysis, I excluded the corporate proxies (the build works in the same manner in the public network), and discovered with Wireshark, that I am receiving TCP RST at some moment from the update site.
At the same time, the build is working for my colleague.
The Maven version is 3.0.5, tried different Tycho versions (0.15.0 - 0.23.0), tried different targets (Kepler, Helios...).
I discovered similar issue, which seems to be still open (https://www.eclipse.org/forums/index.php/t/1071313/).
What could be the reason, for which the update site drops the connections?
The stack trace from Maven:
[INFO] Fetching org.eclipse.core.contenttype.nl_de_3.6.0.v20121120125106.jar (2.58kB of 2.58kB at 0B/s) from http://archive.eclipse.org/technology/babel/update-site/R0.10.1/helios/plugins/
[INFO] Downloading org.eclipse.core.databinding.beans.nl_de
[ERROR] Internal error: java.lang.NullPointerException -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.NullPointerException
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:168)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:665)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:590)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:723)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:287)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:267)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:208)
at org.eclipse.tycho.p2.maven.repository.MavenMirrorRequest.perform(MavenMirrorRequest.java:100)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:707)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:778)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.getArtifacts(CompositeArtifactRepository.java:341)
at org.eclipse.tycho.p2.target.P2ArtifactDownloadTool.downloadArtifactsToLocalMavenRepository(P2ArtifactDownloadTool.java:55)
at org.eclipse.tycho.p2.target.TargetPlatformImpl.downloadArtifacts(TargetPlatformImpl.java:199)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:124)
at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveProject(P2ResolverImpl.java:76)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolvePlatform(P2TargetPlatformResolver.java:448)
at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:425)
at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:98)
at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:64)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:274)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
... 11 more
[ERROR]
FUDForum. Page generated in 0.03553 seconds
