Home » Modeling » TMF (Xtext) » Ecore model not properly registered(ecore model parsing string)
Ecore model not properly registered [message #1725048] Mon, 29 February 2016 05:56 Go to next message
I've created a DSL with xtext 0.7
My goal is to parse a string with this dsl model, but i have some problem with the model registration.
When I try this code
URI dummy =URI.createURI("dummy:/example.cblData");
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(dummy);
InputStream in = new ByteArrayInputStream(preprocessedCode.getBytes());
try {
	resource.load(in, resourceSet.getLoadOptions());
} catch (IOException e) {
	e.printStackTrace();
createResource method always returns null.
URI uriEasyFile = URI.createURI("file://C:/FAST_BP/_work/workspace/pru.cblData");
ResourceSet rs = new ResourceSetImpl();
Resource r = rs.getResource(uriEasyFile, true);
GetResource method thows "Cannot create a resource for 'file://C:/FAST_BP/_work/workspace/pru.cblData'; a registered resource factory is needed"
When I use the "Generic EMF From Editor" the model is opened correctly, but not from my class. Why don't found the Factory if the generic emf editor can open it?.
Thanks in advance.
Jose
Edited for correct some copy/paste errors
[Updated on: Mon, 29 February 2016 06:10] by Moderator
Re: Ecore model not properly registered [message #1725051 is a reply to message #1725048] Mon, 29 February 2016 06:23 Go to previous messageGo to next message
You should call New
YourdslStandaloneSetup().createInjectorAnDoEmfRegistration() somewhere. And
the file extension is case sensitive
Re: Ecore model not properly registered [message #1725052 is a reply to message #1725048] Mon, 29 February 2016 06:28 Go to previous messageGo to next message
I'm not sure if the standalone setup already existed in Xtext 0.7. Are you really sure that it is the ancient version 0.7 and not something more up to date? If you use Xtext nowadays, Christian's answer to call the setup class is correct.
Re: Ecore model not properly registered [message #1725055 is a reply to message #1725051] Mon, 29 February 2016 06:37 Go to previous messageGo to next message
Christian you are right, now the code is:
DataStandaloneSetup.doSetup();
try {
It run correctly.
Thanks!
Re: Ecore model not properly registered [message #1725056 is a reply to message #1725052] Mon, 29 February 2016 06:39 Go to previous message
Karsten:
I know it's very old version, but i'm obliged for compatibility reasons. We are migrating but meanwhile...
[Updated on: Mon, 29 February 2016 06:42] by Moderator
Previous Topic:JvmEnumerationLiteral has no support for parameters
Next Topic:Content assist when model is incomplete
Current Time: Sun Jul 20 16:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.04409 seconds
