Home » Eclipse Projects » Requirements Modeling Framework  » How to set the remove git repository in tool?
How to set the remove git repository in tool? [message #1724869] Fri, 26 February 2016 11:23 Go to next message
I have a git repository on github, but cannot work out from http://formalmind.com/handbook?page=sec-server.html the actual steps in formalmind studio to add in my required details.
Currently it is set up with the local harddrive git details, but I want to be able to synchronise with the github master.
Re: How to set the remove git repository in tool? [message #1724940 is a reply to message #1724869] Sat, 27 February 2016 06:11 Go to previous messageGo to next message
Hi Max,
If I understand correctly, then you do have egit up and running, but you are unclear on how to configure it, correct? In the handbook, we don't describe egit in detail, as this is a different project.
I recommend you to check out this tutorial, which should answer your questions: http://eclipsesource.com/blogs/tutorials/egit-tutorial/
Best,
- Michael
Re: How to set the remove git repository in tool? [message #1725049 is a reply to message #1724940] Mon, 29 February 2016 06:03 Go to previous message
Thanks, I followed that guide.
Previous Topic:Requirement-Diff
Next Topic:Linking between specifications?
Current Time: Sun Jul 20 18:25:27 EDT 2025
Powered by FUDForum. Page generated in 0.02981 seconds
