Home » Modeling » TMF (Xtext) » Xtext 2.8.4 with Maven but without Tycho
Xtext 2.8.4 with Maven but without Tycho [message #1724105] Sat, 20 February 2016 18:21 Go to next message
I would like to provide a maven artifact of my language (based on the terminal grammar) in order to run the generator in other maven projects. What is the best way to do so with Xtext 2.8.4 and without Tycho (no p2 dependencies)?
I have tried using Xtext 2.9.1 with the new project wizard (only maven), migrated all custom files, removed tycho and changed packaging to jar; but when I run "mvn compile" I get a nearly never ending list of the following errors (by the way: generation with eclipse is working):
[ERROR] resolution of uriFragment '|24' failed.
java.lang.UnsupportedOperationException: TODO: import a functional handle on the type resolution that delegates to the best available
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724260 is a reply to message #1724105] Mon, 22 February 2016 10:14 Go to previous messageGo to next message
you can use the 2.9.1 wizard to generate a maven module with no tycho
(choose maven as build System and source layout)
and apply the Workaround in https://www.eclipse.org/forums/index.php?t=msg&th=1074746&goto=1723381&#msg_1723381
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724288 is a reply to message #1724260] Mon, 22 February 2016 15:08 Go to previous messageGo to next message
Hello Christian,
thank you for your suggestion. I created a new project, applied the workaround and copied my dsl. Till then, a "mvn compile" works just fine. But after copying the generators, an OutputConfigurationProvider and a Validator I get the following errors:
[INFO] --- xtend-maven-plugin:2.9.1:compile (default) @ edu.hm.dsl.barrakuda ---
java.lang.UnsupportedOperationException: TODO: import a functional handle on the type resolution that delegates to the best available (current, but evolving) result
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:133)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:80)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:57)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
	at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:129)
	at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:53)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:69)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:55)
	at org.eclipse.xtext.xbase.controlflow.EvaluationContext.resolveTypes(EvaluationContext.java:52)
	at org.eclipse.xtext.xbase.controlflow.EvaluationContext.tryNext(EvaluationContext.java:38)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter.doEvaluate(ConstantConditionsInterpreter.java:111)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter.evaluateAssociatedExpression(ConstantConditionsInterpreter.java:345)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter._internalEvaluate(ConstantConditionsInterpreter.java:246)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter.internalEvaluate(ConstantConditionsInterpreter.java:800)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter.doEvaluate(ConstantConditionsInterpreter.java:114)
	at org.eclipse.xtext.xbase.controlflow.ConstantConditionsInterpreter.evaluate(ConstantConditionsInterpreter.java:124)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$2.accept(LogicalContainerAwareReentrantTypeResolver.java:752)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$2.accept(LogicalContainerAwareReentrantTypeResolver.java:1)
	at org.eclipse.xtext.xbase.typesystem.internal.RootResolvedTypes.processDeferredLogic(RootResolvedTypes.java:209)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:167)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:139)
	at org.eclipse.xtext.xbase.typesystem.InferredTypeIndicator.getTypeReference(InferredTypeIndicator.java:71)
	at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.getEquivalent(XComputedTypeReferenceImplCustom.java:46)
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReferenceFactory.doVisitComputedTypeReference(LightweightTypeReferenceFactory.java:165)
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReferenceFactory.doVisitComputedTypeReference(LightweightTypeReferenceFactory.java:1)
	at org.eclipse.xtext.xtype.impl.XComputedTypeReferenceImplCustom.accept(XComputedTypeReferenceImplCustom.java:27)
	at org.eclipse.xtext.common.types.util.AbstractTypeReferenceVisitor.visit(AbstractTypeReferenceVisitor.java:34)
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReferenceFactory.toLightweightReference(LightweightTypeReferenceFactory.java:83)
	at org.eclipse.xtext.xbase.typesystem.references.StandardTypeReferenceOwner.toLightweightTypeReference(StandardTypeReferenceOwner.java:117)
	at org.eclipse.xtext.xbase.typesystem.internal.ResolvedTypes.doGetDeclaredType(ResolvedTypes.java:994)
	at org.eclipse.xtext.xbase.typesystem.internal.StackedResolvedTypes.doGetDeclaredType(StackedResolvedTypes.java:279)
	at org.eclipse.xtext.xbase.typesystem.internal.ResolvedTypes.doGetActualType(ResolvedTypes.java:957)
	at org.eclipse.xtext.xbase.typesystem.internal.ResolvedTypes.getActualType(ResolvedTypes.java:945)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.getDeclaredType(AbstractLinkingCandidate.java:610)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.getDeclaredType(FeatureLinkingCandidate.java:1131)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.applyToComputationState(AbstractLinkingCandidate.java:288)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState$5.applyToComputationState(AbstractTypeComputationState.java:511)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:1036)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:99)
	at org.eclipse.xtext.xbase.annotations.typesystem.XbaseWithAnnotationsTypeComputer.computeTypes(XbaseWithAnnotationsTypeComputer.java:46)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer.computeTypes(XtendTypeComputer.java:64)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.doComputeTypes(AbstractTypeComputationState.java:121)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractTypeComputationState.computeTypes(AbstractTypeComputationState.java:109)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer._computeTypes(XtendTypeComputer.java:82)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer.computeTypes(XtendTypeComputer.java:56)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer._computeTypes(XtendTypeComputer.java:138)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer.computeTypes(XtendTypeComputer.java:60)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractRootTypeComputationState.computeTypes(AbstractRootTypeComputationState.java:32)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:820)
	at org.eclipse.xtend.core.typesystem.XtendReentrantTypeResolver._computeTypes(XtendReentrantTypeResolver.java:612)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:704)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$DemandTypeReferenceProvider.doGetTypeReferenceWithCurrentTypeResolver(LogicalContainerAwareReentrantTypeResolver.java:205)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$DemandTypeReferenceProvider.doGetTypeReference(LogicalContainerAwareReentrantTypeResolver.java:183)
	at org.eclipse.xtext.xbase.typesystem.util.AbstractReentrantTypeReferenceProvider.getTypeReference(AbstractReentrantTypeReferenceProvider.java:28)
	at org.eclipse.xtext.common.types.util.AbstractTypeReferenceVisitor.doVisitSpecializedTypeReference(AbstractTypeReferenceVisitor.java:50)
	at org.eclipse.xtext.xtype.util.AbstractXtypeReferenceVisitor.doVisitComputedTypeReference(AbstractXtypeReferenceVisitor.java:26)
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReferenceFactory.doVisitComputedTypeReference(LightweightTypeReferenceFactory.java:168)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.resolveArgumentType(AbstractLinkingCandidate.java:627)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.resolveArgumentType(FeatureLinkingCandidate.java:958)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.computeFixedArityArgumentType(AbstractLinkingCandidate.java:579)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.computeArgumentType(AbstractLinkingCandidate.java:443)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.computeArgumentTypes(AbstractLinkingCandidate.java:430)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.preApply(AbstractLinkingCandidate.java:378)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.preApply(FeatureLinkingCandidate.java:891)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractLinkingCandidate.applyToComputationState(AbstractLinkingCandidate.java:286)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:468)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:105)
	at org.eclipse.xtext.xbase.typesystem.computation.ClosureWithExpectationHelper.computeTypes(ClosureWithExpectationHelper.java:99)
	at org.eclipse.xtext.xbase.typesystem.computation.ClosureTypeComputer.computeTypes(ClosureTypeComputer.java:48)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer._computeTypes(XtendTypeComputer.java:205)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.computeTypes(XbaseTypeComputer.java:111)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.getConformanceFlags(AbstractPendingLinkingCandidate.java:993)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.getConformanceFlags(FeatureLinkingCandidate.java:546)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.compareByArgumentTypes(AbstractPendingLinkingCandidate.java:797)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.compareByArgumentTypes(FeatureLinkingCandidate.java:608)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.compareByArgumentTypes(AbstractPendingLinkingCandidate.java:673)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.compareByArgumentTypes(FeatureLinkingCandidate.java:599)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.compareTo(AbstractPendingLinkingCandidate.java:582)
	at org.eclipse.xtext.xbase.typesystem.internal.FeatureLinkingCandidate.compareTo(FeatureLinkingCandidate.java:737)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.compareTo(AbstractPendingLinkingCandidate.java:517)
	at org.eclipse.xtext.xbase.typesystem.internal.AbstractPendingLinkingCandidate.getPreferredCandidate(AbstractPendingLinkingCandidate.java:479)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer.getBestCandidate(XbaseTypeComputer.java:1043)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:1032)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:460)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeMemberTypes(LogicalContainerAwareReentrantTypeResolver.java:890)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:879)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:698)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:690)
	at org.eclipse.xtend.core.typesystem.XtendReentrantTypeResolver.computeTypes(XtendReentrantTypeResolver.java:382)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:163)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer._computeTypes(XtendTypeComputer.java:117)
	at org.eclipse.xtend.core.typesystem.XtendTypeComputer.computeTypes(XtendTypeComputer.java:58)
	at org.eclipse.xtext.xbase.typesystem.internal.ExpressionTypeComputationState.doComputeTypes(ExpressionTypeComputationState.java:59)
	at org.eclipse.xtext.xbase.typesystem.computation.XbaseTypeComputer._computeTypes(XbaseTypeComputer.java:472)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._computeTypes(LogicalContainerAwareReentrantTypeResolver.java:738)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:702)
How can I debug in order to find the "bad" xtend-generator-file or config (there are no warnings/errors in eclipse)?
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724291 is a reply to message #1724288] Mon, 22 February 2016 15:33 Go to previous messageGo to next message
I have no idea on that. If mvn and eclipse behave differently it is
definitively a bug. What you can try to comment out stuff in the generator
until it works. Or you start with a empty generator and and stuff method by
method
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724668 is a reply to message #1724291] Thu, 25 February 2016 06:26 Go to previous messageGo to next message
Till now, not everything is copied back to the new project, but its working. In the custom OutputConfigurationProvider I have defined a custom-config in order to clear a specific path. With the open Eclipse Application and my language I can run the clean with "project -> clean...", but how can I do this with the main-class of the language (without eclipse)?
Do I have to write a method on my own using:
fileAccess.deleteFile(fileName, outputConfiguration);
[Updated on: Thu, 25 February 2016 06:30] by Moderator
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724670 is a reply to message #1724668] Thu, 25 February 2016 06:39 Go to previous messageGo to next message
yes you have to do it manually.
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724672 is a reply to message #1724670] Thu, 25 February 2016 06:45 Go to previous messageGo to next message
Thanks. I thought xtext would be a little bit more generic.
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724674 is a reply to message #1724672] Thu, 25 February 2016 06:49 Go to previous messageGo to next message
the problem is: in eclipse this is handled by the builder. standalone you have none.
Re: Xtext 2.8.4 with Maven but without Tycho [message #1724676 is a reply to message #1724674] Thu, 25 February 2016 07:00 Go to previous message
Indeed, I saw it in the cleanOutput-method of the BuilderParticipant-class. This was, why I asked.
[Updated on: Thu, 25 February 2016 07:01] by Moderator
Previous Topic:Cross-reference issues
Next Topic:problem of coloration keywords
Current Time: Sun Jul 20 08:20:20 EDT 2025
Powered by FUDForum. Page generated in 0.05084 seconds
