Home » Archived » Buckminster » P2 update for RCP product fails
P2 update for RCP product fails [message #1722710] Mon, 08 February 2016 08:22 Go to next message
Hi all,
I've facing a problem with the update functionality and hope you can
give me an advise.
Here is the setup:
1. The product is based on features.
2. The product contains two features: the product feature and p2.core.
3. The product feature contains all other features, the branding plug-in
and the update plug-in.
Also in the "available software" dialog the product feature shows the
"new" icon instead of the "update available" icon.
The error message I receive is
   Your original request has been modified.
     Product is already installed, so an update will be performed instead.
  Only one of the following can be installed at once:
     Branding Plug-in 1.0.0.201602081058
     Branding Plug-in 1.0.0.201602081040
   Cannot satisfy dependency:
     To: product.feature [1.0.0.201602081041-7yC8EC9cD-Cn-BgODOkEYMoCqVOD]
     From: product.feature 1.0.0.201602081041-7yC8EC9cD-Cn-BgODOkEYMoCqVOD
     To: product.branding [1.0.0.201602081040]
     From: product.feature 1.0.0.201602081059-7yC8EC9cD-Cn-BgODOkEYMoCreOD
     To: product.branding [1.0.0.201602081058]
The "about > installed software" dialog shows the produt as root node
which contains the product feature as a child. This is probably causing
the problem because only root nodes can be updated, right?
I think to update the feature independently from the product definition
I would need to mark it as installMode="root" (which seems to be a Tycho
concept). Or I need to have the product itself installable at the update
site, too.
So I have the following questions:
1. Why is the product qualifier (specified in the product definition
file) not replaced?
2. Why doesn't the product itself update from the p2 site (which
includes the product executables in the "binary" directory though)?
3. What do I need to change in my setup to fix the conflict shown above
(making it work somehow)?
4. Do I need to switch to Tycho for that?
Thank you very much!
Axel
[Updated on: Mon, 08 February 2016 08:26] by Moderator
Re: P2 update for RCP product fails [message #1723956 is a reply to message #1722710] Fri, 19 February 2016 04:32 Go to previous messageGo to next message
do you have any idea how to proceed with this issue?
Axel
Am 08.02.2016 um 14:22 schrieb Axel Guckelsberger:
> Hi all,
> give me an advise.
> Here is the setup:
> From: Product 1.0.0.qualifier
> site, too.
> file) not replaced?
> Axel
Re: P2 update for RCP product fails [message #1724224 is a reply to message #1722710] Mon, 22 February 2016 06:13 Go to previous messageGo to next message
On 08/02/2016 14:22, Axel Guckelsberger wrote:
> Hi all,
> give me an advise.
> Here is the setup:
> site, too.
> file) not replaced?
> Axel
Hi Axel
I think that you can still update features independently from the
product definition as long as the feature of the product *depends* on
such features, and not *includes* such features. In fact, including a
feature results in a exact version range for that feature, while when
you depend on a feature (or plug-in) you can 'relax' the dependency
version range (and you can specify no range at all).
However, note that the features and bundles your feature depends on,
will NOT be included in the generated p2 repository. This means that
you may have to produce different repositories yourself (e.g., one for
the product's feature and one for the dependency features). You can
then (b3)-aggregate them or create a composite update site.
Hope this helps
cheers
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: P2 update for RCP product fails [message #1725091 is a reply to message #1724224] Mon, 29 February 2016 11:50 Go to previous message
Hi all,
I finally found the solution :-)
The actual problem was that the updated product was never recognised,
because the product's qualifier has not been dynamically replaced.
1.0.0.qualifier was always installed already, so no upgrade was found.
The solution is here:
https://www.eclipse.org/forums/index.php?t=msg&th=155943&goto=491414&#msg_491414
While searching in the newsgroup I've found several posts from Thomas
where he explained that. But it is still not very obvious and looks like
insider knowledge. Thus, please add this to the official documentation.
HTH,
Axel
> Hi Axel
> Hope this helps
> cheers
> Lorenzo
Previous Topic:Buckminster adds version ranges to my plugins when building p2 site
Next Topic:Target platform not materializing
Current Time: Sun Jul 20 03:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.02866 seconds
