Home » Eclipse Projects » NatTable » Default sorting when no explicit sort is applied
Default sorting when no explicit sort is applied [message #1723681] Wed, 17 February 2016 03:51 Go to next message
I created a SortedList using a specified Comparator to determine sort order.
When NatTable is instantiated it sorts correctly but when sorted ascending, descending, and unsorted my list is unsorted again.
I want to have a default sort when there is no explicit sort is applied (unsorted)
How do I achieve that?
Re: Default sorting when no explicit sort is applied [message #1723693 is a reply to message #1723681] Wed, 17 February 2016 04:33 Go to previous messageGo to next message
Pre sort your collection before adding it to NatTable
Re: Default sorting when no explicit sort is applied [message #1723695 is a reply to message #1723681] Wed, 17 February 2016 04:38 Go to previous messageGo to next message
Hi Dirk,
that might be a solution for fixed data but we have a dynamic collection.
Re: Default sorting when no explicit sort is applied [message #1723707 is a reply to message #1723695] Wed, 17 February 2016 05:32 Go to previous messageGo to next message
Then you could have a look at SortedList constructor. Although I'm not sure if the NatTable sort mechanism is working with specifying a comparator that way
Re: Default sorting when no explicit sort is applied [message #1723795 is a reply to message #1723681] Thu, 18 February 2016 01:52 Go to previous message
NatTable sets the comparator to null when unsorting the table.
I managed to achieve my default sorting by extending NatTableComparatorChooser.
Although I'm not so happy with my solution it works for now, there might be some performance problems because rebuildComparator is called about 3 times when clicking on a column to sort
private class MyNatTableComparatorChooser<T> extends NatTableComparatorChooser<T> {
        private final Comparator<? super T> defaultComparator;
        public AlarmNatTableComparatorChooser(final SortedList<T> sortedList,
                final TableFormat<T> tableFormat) {
            super( sortedList, tableFormat );
            defaultComparator = sortedList.getComparator();
        protected void rebuildComparator() {
            super.rebuildComparator();
            // select the new default comparator
            sortedList.getReadWriteLock().writeLock().lock();
            try {
                if( sortedListComparator == null ) {
                    sortedListComparator = defaultComparator;
                    sortedList.setComparator( defaultComparator );
            } finally {
                sortedList.getReadWriteLock().writeLock().unlock();
Previous Topic:Having issue with Mapping Child-Parent in Tree
Next Topic:Inconsistent API
Current Time: Sat Jul 19 20:55:52 EDT 2025
Powered by FUDForum. Page generated in 0.03795 seconds
