Colors resets on startup! [message #1723036] |
Thu, 11 February 2016 03:20  |
When I start ecplipse i see my colors (preferences/java/editor/syntax coloring) as I set them for 2 seconds, then it resets all colors to the current theme (dark theme).
If i then close and restart Ecplise the colors are reset from the beginning.
I can bypass this by importing my prefereces from a file, but i dont want to do this EVERY time i start Eclipse, what can be wrong?
Erik
Re: Colors resets on startup! [message #1723156 is a reply to message #1723036] |
Fri, 12 February 2016 03:55   |
Erik,
Maybe you had the preference recorder enabled and have recorded these
preferences previously so now they are being applied during startup.
You can use Navigate -> Open Setup -> Open User to open the Oomph setup
file in which your preferences would have been recorded. If you have a
preference file you often import manually, you can convert them to Oomph
preference tasks so that they're automatically applied to all your
workspaces. To do that, open the User setup as I just explained, and
find the toolbar button with the hover text "Import Preferences" (it's
likely near the far right of your toolbar area). In the dialog that
comes up, you can specify your Eclipse preference file, and see which
preference tasks are available in that file so you can choose which ones
you want always applied to all your workspaces of all your installations.
You could also choose to delete some or all the preference tasks in your
User.setup if you don't want them applied to all workspaces.
On 11.02.2016 16:49, erik hellstrom wrote:
> Hi
> beginning.
> Thanks
> Erik
Re: Colors resets on startup! [message #1852065 is a reply to message #1852050] |
Thu, 28 April 2022 06:01  |
If you don't have that menu item from the main menu bar and you don't have Window -> Preferences -> Oomph in the preferences dialog then you don't have Oomph installed and your issue must be caused by something else.
If you open the Error log view (Window -> Show view...), use the big red X button to clear all the events, and then use File -> Restart, is anything showing up in the Error log view that might give a clue of something that's happening or going wrong during startup?
FUDForum. Page generated in 0.07939 seconds
