NoClassDefFoundError DefaultBpmn2RuntimeExtension$RootElementParser - after update to 1.2.3 [message #1722901] |
Wed, 10 February 2016 03:44  |
when I update the bpmn2 plugin from release 1.2.2 to latest release 1.2.3 (http://download.eclipse.org/bpmn2-modeler/updates/mars/1.2.3), I got the following exception when opening a model created with the bpmn plugin version 1.2.2 before.
!ENTRY org.eclipse.e4.ui.workbench 4 0 2016-02-10 09:33:42.369
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '1222'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: org/eclipse/bpmn2/modeler/ui/DefaultBpmn2RuntimeExtension$RootElementParser
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:356)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
Is there any other dependency which users need to update when upgrating to 1.2.3?
Tested with: 1.2.3.CR2-v20160209-2002
thanks for help
Ralph
FUDForum. Page generated in 0.03676 seconds
