Home » Modeling » OCL » Problems with hierarchical/embedded model packages(Problems with hierarchical/embedded model packages)
Problems with hierarchical/embedded model packages [message #1722541] Fri, 05 February 2016 09:23 Go to next message
I found the following issue when playing around with OCL:
My model is the following:
package1
package2
class
attribute
CompleteOCL for the model:
import 'model.ecore'
package package1::package2
context class
inv SomeCheck: self.attribute = 'someValue'
endpackage
When I tried to check the model programatically with the well known Diagnostician I always got parsing errors for the ocl file saying that it cannot recognise package2 and class and its attributes.
When I moved the class to package1 the OCL check was working as supposed without parsing errors.
Is this a feature limitation or a bug?
Thanks, Zoltan
Re: Problems with hierarchical/embedded model packages [message #1722551 is a reply to message #1722541] Fri, 05 February 2016 11:19 Go to previous messageGo to next message
Sounds like an old bug. Try a more recent version.
https://wiki.eclipse.org/OCL/ForumNetiquette
Ed Willink
On 05/02/2016 16:13, Zoltan Matyas wrote:
> Hello,
> package1
> package2
> class
> attribute
> context class
> endpackage
> Thanks, Zoltan
Re: Problems with hierarchical/embedded model packages [message #1723158 is a reply to message #1722551] Fri, 12 February 2016 04:11 Go to previous messageGo to next message
I use the latest eclipse (4.5.1), OCL SDK 5.1 and OCL Ecore 3.5. If I try to update my eclipse it does not find any.
BR, Zoltan
OCL Mars updates (was Re: Problems with hierarchical/embedded model packages) [message #1723165 is a reply to message #1723158] Fri, 12 February 2016 04:46 Go to previous message
The Mars.1 6.0.1 release is available from
http://download.eclipse.org/releases/mars
However I understand that the inadequacy of Eclipse Update is a known
issue for which I can only apologize.
6.0.2 will be available in a couple of weeks; no functional changes are
anticipated from 6.0.2RC3.
The OCL downloads page
https://www.eclipse.org/modeling/mdt/downloads/?project=ocl
is updated automatically and so you can find 6.0.1 and 6.0.2RC3 (and
6.1.0M5) there reliably.
The OCL updates sites require a little manual registration; I've just
fixed a couple of bugs. You should now be able to update to
6.0.1 from http://download.eclipse.org/modeling/mdt/ocl/updates/releases
6.0.2RC3 from
http://download.eclipse.org/modeling/mdt/ocl/updates/milestones/6.0.2
The changes, which are very relevant to UML users, are listed on
https://wiki.eclipse.org/OCL/New_and_Noteworthy/Mars
Ed Willink
On 12/02/2016 09:11, Zoltan Matyas wrote:
> Hello,
> BR, Zoltan
Previous Topic:Parsing error in a UML::Constraint
Next Topic:Non documented dependency for OCLinEcore
Current Time: Sun Jul 20 05:58:32 EDT 2025
Powered by FUDForum. Page generated in 0.05255 seconds
