Home » Eclipse Projects » Sirius » Reorder elements on diagram, tree or table
Reorder elements on diagram, tree or table [message #1722181] Wed, 03 February 2016 04:28 Go to next message
Is it possible to reorder elements on diagram, tree or table editors?
Re: Reorder elements on diagram, tree or table [message #1722255 is a reply to message #1722181] Wed, 03 February 2016 10:37 Go to previous messageGo to next message
Hi Denis,
Le 03/02/2016 10:29, Denis Nikiforov a écrit :
> Hi
Sirius displays graphical elements from the order of their computation:
they are sorted by mapping and by the result of the semantic candidates
expression of their mapping.
So if you want to reorder some elements you will have to reorder the
corresponding semantic elements (from semantic tab of the properties
view, or tools or actions/menu).
Maxime - Obeo
Re: Reorder elements on diagram, tree or table [message #1722308 is a reply to message #1722255] Thu, 04 February 2016 00:34 Go to previous messageGo to next message
In "Sample Ecore Model Editor" or "Sample Reflective Ecore Model Editor" one can reorder EClasses or EFeatures by drag'n'drop.
Is it possible to implement a similar functionality in tree or table view? I can't find a drag'n'drop tool for these views.
Re: Reorder elements on diagram, tree or table [message #1722482 is a reply to message #1722308] Fri, 05 February 2016 03:58 Go to previous messageGo to next message
Hi Denis,
In the TreeDescription you have the possibility to use a drop tool, you
will not have the insertion feedback (line) between element, but you
could use this to place the dropped element before/after the target of
the drop.
There is no current way to this reorder from the Viewpoint Specification
Model but this could be an interesting idea.
Maxime - Obeo
Re: Reorder elements on diagram, tree or table [message #1722499 is a reply to message #1722482] Fri, 05 February 2016 04:56 Go to previous messageGo to next message
I've got it. Thanks! It seems that it will work for tree views! I can reorder by external java action.
Is it possible to handle drag'n'drop in table views? Maybe I can extend sirius programmatically?
Re: Reorder elements on diagram, tree or table [message #1725099 is a reply to message #1722499] Mon, 29 February 2016 13:18 Go to previous messageGo to next message
I am interested in reordering list elements in a diagram view.
Any way to implement this from outside, maybe by an additional edit part
policy?
Axel
Am 05.02.2016 um 10:56 schrieb Denis Nikiforov:
Re: Reorder elements on diagram, tree or table [message #1725785 is a reply to message #1725099] Mon, 07 March 2016 10:50 Go to previous messageGo to next message
> policy?
It's not possible directly (through the VSM) to react to graphical
reordering of list elements on diagrams, but you could probably define
"Popup Menus" (context menu items) on the list elements corresponding to
the "Move Up" and "Move Down" operations. Not as convenient as a
Drag'n'drop from user's point of view, but depending on the use case it
could be sufficient.
Otherwise you can override the edit part implementation and/or edit
policies used by Sirius for selected items with the standard GMF
extension point. See for example at [1] how UML Designer does it. If
you're familiar enough with GEF/GMF you may be able to provide a custom
"DragDropPolicy" doing what you need (not tested though).
Pierre-Charles
[1]
https://github.com/ObeoNetwork/UML-Designer/blob/master/plugins%2Forg.obeonetwork.dsl.uml2.design%2Fplugin.xml#L93
Pierre-Charles David - Obeo
Re: Reorder elements on diagram, tree or table [message #1726676 is a reply to message #1725099] Tue, 15 March 2016 11:30 Go to previous message
For diagram there is already a feature request [1].
For table we can do sorting by clicking on column header or line, see
SortColumnsByLineAction & SortLinesByColumnAction. But we don't have
drag'n drop feature in table, you can raise a feature request through
the Sirius bugzilla if you want.
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=478039
Best Regards.
> policy?
> Cheers,
> Axel
Esteban Dugueperoux - Obeo
Previous Topic:Edge on another Edge
Next Topic:Listen for changes on a diagram element
Current Time: Sun Jul 20 13:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.04090 seconds
