SetupTask with filter [message #1721593] |
Thu, 28 January 2016 09:33  |
I'm trying to create a SetupTask that is OS specific. For that I used the build 1.3.0 (Build 2159) that should include the fix described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=429245
But I can't figure out how to use the condition. I've tried with:
<setupTask
xsi:type="setup:ResourceCreationTask"
content="test"
targetURL="${user.home/test.log}"
filter="(osgi.os=linux)"
and some variations around this, but I don't manage to make it work.
Could you give me some examples on how this filter should work? Or if I need to take another approach.
Thank you,
Catalin
Re: SetupTask with filter [message #1722076 is a reply to message #1722071] |
Tue, 02 February 2016 11:11   |
Catalin,
Note that once the resource exists, the task will be disabled, so
perhaps that's a point of confusion? Presumably you are on Linux?
If you provision an environment for Oomph itself, you can use a debug
launch of "Setup (Installer Dialog)" and set a breakpoint in
org.eclipse.oomph.setup.internal.core.AbstractSetupTaskContext.matchesFilterContext(String)org.eclipse.oomph.setup.internal.core.AbstractSetupTaskContext.matchesFilterContext(String)
On 02.02.2016 16:43, Catalin Samarghitan wrote:
> Thank you for your answer.
> I've used the build only for the installer, not for creating the
> installations.
> I can see that in the plugins folder I have a good version:
> 198049 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.core_1.3.0.v20160106-0618.jar
> 2610879 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.doc_1.3.0.v20150923-0945.jar
> 139039 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.edit_1.3.0.v20160106-0618.jar
> 681510 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.installer_1.3.0.v20160106-1533.jar
> 39785 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.p2_1.3.0.v20160106-0618.jar
> 23946 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.p2.edit_1.3.0.v20150923-1022.jar
> 101944 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.sync_1.3.0.v20151212-0853.jar
> 585318 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.ui_1.3.0.v20160106-1533.jar
> 340478 Jan 26 06:44
> plugins/org.eclipse.oomph.setup.ui.questionnaire_1.3.0.v20151231-0813.jar
>> That works for me. It's easy to test whether it's working by virtue
>> of the task being present in the installer's confirmation page...
> This is what I do, I check if the step is present on the Bootstrap
> Tasks page. And is not.
> Just to check if the filter works, I've tried to set it to true or
> (1=1), even so the task does not appear in the list.
> Is there a way to enable more logging to debug the operations?
> Thank you,
Re: SetupTask with filter [message #1725166 is a reply to message #1725139] |
Tue, 01 March 2016 05:26  |
Catalin,
Thanks for confirming. :-) It was an easy fix; sorry it took so long.
On 01.03.2016 09:51, Catalin Samarghitan wrote:
> It works with the latest build.
> Thanks!
FUDForum. Page generated in 0.04512 seconds
