Home » Archived » BIRT » How can I execute a SELECT statement in an expression?
How can I execute a SELECT statement in an expression? [message #1721822] Sun, 31 January 2016 09:41 Go to next message
Greetings,
I have followed request:
I have a DB table with three columns:
company_unit, topic, amount
In BIRT, I need a "computed column" with this idea:
if (BirtStr.search("*reserved*",row["topic"],1) > -1)
row["amount"] - (SELECT sum([amount])
FROM db.pmo
WHERE company_unit=row["company_unit"]
else
row["amount"];
or in other words:
Thank you!
Michael
Re: How can I execute a SELECT statement in an expression? [message #1722582 is a reply to message #1721822] Sat, 06 February 2016 00:41 Go to previous message
Are you trying to calculate the following:
SUM amount
Where topic <> "*reserved*"
If so, maybe you could use the aggregation function to do this:
* In the table (or graph, ...) where you use the data, open "Binding" window of the Property Editor.
* Add Aggregation
* Set Function: SUM
* Expression:
if (row["topic"] == "*reversed*")
   0;
else
   row["amount"];
Previous Topic:Designing more flexible Layout
Next Topic:Can not load the report query
Current Time: Sat Jul 19 22:37:57 EDT 2025
Powered by FUDForum. Page generated in 0.43862 seconds
