Find annotated model element from other file in Inferrer [message #1721434] |
Wed, 27 January 2016 08:19  |
I'm totally stuck with this..
I have a DSL bases on XBase.
In my inferrer I need a JvmTypeReference to another inferred type of another file of my model whose JvmGenericType is annotated with an specific annotation.
My problem is that in the index I just have proxies at inferrer time!
At all, the inferrer are making big troubles to me. It is too limited. For example, I also need a JvmTypeReference of a generic type parameter from the type of an XExpression. Not possible!?
Please help me with that,
~Ingo
Re: Find annotated model element from other file in Inferrer [message #1721937 is a reply to message #1721434] |
Mon, 01 February 2016 12:47  |
Ingo Meyer wrote on Wed, 27 January 2016 13:19Hi,
Do you know the name of that inferred type? Or do you have a handle to the referenced resource to look it up?
It should work by navigating cross references, up to the point, at least where there is no bi-direcational dependency, i.e. the type you are looking for needs the type you are currently inferring.
It would help if you could outline your scenario with an example. But you cannot resolve anything inside XExpressions during model inference, because the Expression needs a stable structural environment (scope) to be resolved.
It sometimes helps to explain the problem you want to resolve, as often there are alternative ways to solve it.
Sven
FUDForum. Page generated in 0.24397 seconds
