NodeMappingImport loses bordered nodes of imported node [message #1719939] |
Wed, 13 January 2016 06:11  |
I am trying to understand the Sirius Documentation, more specifically
the section on node mapping imports:
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#diagram_extension
I have attached an example that's based on the sample family model from
sirius:
I added two additional classes Wallet and Lover, and two new containment
references to the Man class: wallet, lovers.
I then added a BorderedNode to the existing Man mapping, so that a Man's
wallet is displayed as a BorderedNode in a family diagram. This works fine.
I now add a Diagram Extension that defines an additional layer which
should also display a Man's lover as a bordered node. To do so, I create
a NodeMappingImport which imports the original Man mapping. I then add a
new BorderedNodeMapping child that will create bordered nodes for a
man's lover.
Now, from the documentation I understand that if I enable the extension
layer, a Man should display both, bordered nodes for wallets, and
bordered nodes for lovers. What happens however is that when I enable
the extension layer, the lovers nodes appear but the wallets nodes
disappear. If this is expected behaviour, then the documentation is
quite misleading.
Thanks for comments,
Felix
Re: NodeMappingImport loses bordered nodes of imported node [message #1720984 is a reply to message #1720969] |
Fri, 22 January 2016 04:42   |
Hi Felix,
On 01/22/2016 10:14 AM, Felix Dorner wrote:
> Hi Florian,
> On 21-Jan-16 11:46, Florian Barbin wrote:
>> By default the sub-nodes of an imported mapping are not displayed. You
>> need to explicitly add the border node you want to reuse in "Reused
>> Bordered Node Mappings" in the "Import" tab.
> I see. So if I am the maintainer of an extension like that, I have to
> continuously monitor the extended .odesign files for additions/removals
> of its child bordered nodes, or I risk that my extension doesn't show
> nodes that have been newly added, or also that my extension shows nodes
> that have been removed.
I agree with that. Ideally, the specifier should have the possibility to
add all imported mapping sub-node by default. That sounds like a good
feature request.
> So I have this crazy idea to avoid this problem, maybe you have
> comments: Shouldn't it be possible that I 'fix' my extension dynamically
> at runtime by updating its mapping model so that it always reuses
> exactly the bordered nodes of the imported mapping plus my own added
> borded node.
It is a possibility. But you have to make sure the VSM model is properly
updated before opening any representation to avoid a refresh with the
"old" VSM.
> Felix
Florian - Obeo
Re: NodeMappingImport loses bordered nodes of imported node [message #1720999 is a reply to message #1720984] |
Fri, 22 January 2016 06:41  |
On 22-Jan-16 10:42, Florian Barbin wrote:
> Hi Felix,
>> Hi Florian,
> feature request.
You mean in the specifier editor? That would save some time, but still
keep the maintenance burden, since the imported mapping might change
over time.
>> borded node.
> "old" VSM.
I will have a look, but IIRC the ViewpointRegistry API will give me a
hard time to transform/update a VSM model before it's registered (or used..)
>> Felix
FUDForum. Page generated in 0.04387 seconds
